ok, 99vic just called me with a good question, can you run chassi or engine block ground to the negative on your battery? he said he could not get on smd it just gives him a error message or else he would have posted this himself, please help and include all possible grounding ways please!
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
I believe you have to run the wire from the engine block directly to the frame, cause otherwise the ground is really serving no purpose since it will still be flowing through you battery ground...if that makes any sense.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
after u ground the engine block to the frame, can u ground the battery to the engine block? or do u have to do it to the frame as whell
My F-150 Build
if you went from engine block to frame then batt neg to engine block, that means that the electricity has to flow through more metal (more resistance) to get to the batt negative from the ground where the amps are. LOL, unless the amps are grounded to the engine block!! :rofl:
Loud as f*ck, and sounds good doing it.
Team built from here on out!!!!
BIG things to come.........
Missing link is the shite!!!
tell him to ground from the bolt on the alternator bracket. The alternator is directly bolted to the engine. run a ground cable from there to the frame of the car.
see the mount. That is the ground that runs to the frame. Then run the batt negative to the frame. Does not have to be the same spot of the frame, just the frame.
ok i finally got on for some reason i couldnt, thanks logan,
what i did was there was a small wire coming from the - post to the skin of my car i added wire to that
then i ran a wire from the - on the battery to a bolt on my engine
so i was wondering if i ran a strand from the + on the battery to the alt if that would be the big 3
my big problem is i camt find a ground from the engine to the frame anywhere on my car
Edited by 99vic
REST IN PARADISE BIG RICH (Sqmonte) never forgotten
Why do you guys ALWAYS dispute on NUMBERS?????
It's such a played out argument, so fucking annoying....
It's 12 fuckin 15's.... It's louder than you... Shut the fuck up...
/Rant
I'm so jealous, it makes me want to club baby seals. That shit gets down HARD!
dont buy from knowledge he will scam you.
http://www.stevemeadedesigns.com/board/topic/30995-official-knowledge-feedback/
  • Who's Online   0 Members, 0 Anonymous, 990 Guests (See full list)
