Okay so I decided against 18's. Not enough room. So I decided to go with 4 12's, most likely FiBL's or FiQ's. Whats the difference between the 2, I noticed that the majority of the specs. are closely the same. So which one should I choose for a daily pounded, good sounding sub, I also chose these because the rec. airpsace is around the same as the MTX's I have now so I can use the same box that I am building for them for the Fi's.
Also since both Fi's are 1,000W RMS, would it be better to go with 4 t1000.1bd's or 1 t4000.1bd, or are there any other more affordable amps out there I could use, keep in mind I AM upgrading my electrical with an HO alt. and all 1/0 and 2 batteries in back.
Thanks for your time
E-Train
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
Okay I just did the math and it the 1 4k amp would be about 400 bucks cheaper than for 1k's, but i still don;t wanna spend 2800 bucks on ONE amp, any cheaper amps out there that would do the trick?
1997 4 Runner
Alpine CDA-9886
you just have to remember that rockfords put out alot more power then they say. the q's are aimed more at daily driver, better sound quality over the bl. the bl will get louder tho, but lacks the sound quality that the q's have. also the q's i believe have like 27mm xmax which is nice xD.
one larger amp will be easier to set and tune, also it will more then likely be cheaper.
IMO i would go with the Q's and a t4k, but thats me. good luck
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
brand new 1400 bucks on ebay
http://cgi.ebay.com/NEW-ROCKFORD-FOSGATE-P...1QQcmdZViewItem
94 3000gt
18" Kicker Solo X
KX2500.1
2 KX350.4
8 JBL Coax Speakers
250A Mechman Alt
yeh you'd do better with one T40001bd than 4 T1ks ..... less wires and less troubleshooting if it ever came down to it. i'm sure you can find the T4K for cheap. look around potna and good luck on the build. do at least two runs of 1/0 can only one run is good for around 3500rms.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
that link is to a t4k,
you could look into hifonics xxv's or something along those lines. cheaper and still puts out decent power. whats ur budget? people will be better able to help if we knew sum information
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
shit ton-o-wire
Team SMD
  • Who's Online   0 Members, 0 Anonymous, 2792 Guests (See full list)
