Rebuildin' 2003 Grand Am
doing something similar w/stain on the back of the box which will be seen thru the cabin to trunk entrance
Posted Image
got 1 sub today..... very very happy to see it reads 2.8ohms... so the amp will see .7ohm, imo perfect match.. should see 2000w even after impedence rise
Posted Image
sx sexiness.. love me some subs without boobs
Posted Image
coils look purty too... bright orange flatwound copper
slowly but surely
got a little done.... im really held back cause i work 11-7 usually and its cold so i cant do the fiberglass resin til tomorrow and tuesday 11/3-11/4... always behind schedule lol
Posted Image
should have more progress tomorrow... at least some glassing done... maybe put the top on and start staining
hopefully seeing that picture of the back of the box next to my avatar lets you see the direction im going.. trying to match all the woodgrain and lettering since i should have this setup for awhile
got the top on
wasnt fast enough cleaning the glue off so looks like its gonna be fleckstone all around...lol woops
Posted Image
Posted Image
glassing tomorrow both boxes... woohoo
how important in my case would it be to add a 2nd baffle... even 1/2... its braced pretty well but i cant decide
would putting resin and a layer of mat be somewhat equivalent?
ill conjure up something tomorrow... was gonna use t-nuts.. might try that too
I really like the way your box turned out. I don't know if I would put a second baffle on it or not. I don't have one on my box, but if I would have had the room to do so I think that I probably would have done it. If you have enough wood to cut out the entire face not just where the woofers mount also around where the port is I say do it. Otherwise it may look a little strange with the double baffle just where the woofers are and not around the port. You could cut the second baffle a 1/4" small all the way around and fill it with bondo to give it a nice effect. I've done it before with a box and it looked pretty cool. Either way you do it I'm sure it's gonna turn out great. I love the theme that you're using so far in your build. The wood finish is very rare to see in a build these days and I really like how your pulling it off. Keep up the good work. I'm also curious to see how well those AQ amps work.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
thanks for the comments for those of u who troll my build... it takes so long sometimes to get things going
the other problem with double baffle is it will bring tuning down even more... and its already at 30.13, which i was hesitant to go that low with the sx's anyways
those boxes are looking real good decaf....can't wait to see the finished product with many vids i hope lol
im a vid hype, i take a few a day for the first month it seems of having a new setup.... i have sooooo many new songs that are goldmines waiting to screw around with
I always wondered why no one used stain as much... i always thought it was classy, much more so if i had trim in the car to match wood with... i also kinda got insipired by "sleepys" envoy w/2 18"hdc3 +mm4000 from ca.com... its half fleckstone and half stain...
hopefully... if everything goes as planned... both boxes will be done tomorrow
lucas's needs a plunge router around port opening + 3 45s of resin
mine needs same routing and 1 45 of resin and resin on the outside
