Well...?
Sorry, I'm new to this, also, since I'm needing each port to be 24.40" (flared port length), where do I measure for that?
http://www.partsexpress.com/pe/pshowdetl.c...352&scqty=2
EDIT: ok.
what i meant was, say i get 4" pvc pipe.
would the flares included with the aeroports work?
Edited by emat19876
no, pvc will not be a areo port. pvc will just be a round port.
Unless you flair the ends, but whats to say you will get a proper flare on both ends, and if you dont it may cause turbulence or port noise.
and areo ports can be tuned and tuned again if you got spare sleeves. very easy for swapping out ports.
Edited by audiofanaticz
well, what i meant, was using the flares that comes with the aero, but the included "straight" pipe isn't long enough for me to do a 35hz tuning, hence why i need pvc to substitute the non-flared pipe that's included.
2 ports sounds like too much for a single sub in a 2.10 cubed box. but thats just meh.
12*2.10=25.2
16*2.10=33.6
Meh, I'll try it out, if I don't like it, I'll block one port off.
ok.
i dont believe the PP flares will work on PVC pipe.
the PVC i have is 1/4" thick and the PP i've used was either 1/8" thick or thinner (pretty damn thin after using PVC)
Hope that helps.
-Drew
uhoh_45 said:
Hope that helps.
-Drew
K cool, thanks!
Yay, I can finish my box next week... if the box isn't too big. (originally designed for slot port, fucked up the port cutout... doing Aeroport instead.
EDIT: FUCK I READ THAT WRONG....
Edited by emat19876
use MDF to make the flares, dont be a sissy
lol... jk
I have a fat ass round over bit I use, and I double up on the wood, recess the PVC
No its not a true aero, but you hear---- Nothing
Just clean solid bass
This is with just a 3/8s round over, I have about a 3/4" round over now, so that lip is ALOT wider, and thats a 6" PVC just for comparison, that box is bigger than it looks
  • Who's Online   0 Members, 0 Anonymous, 1088 Guests (See full list)
