Voltage
Ive got 4 18" treo ssi subs in a 16 cubic foot box an 200 sqr inch port . running a treo ssx 2ooo.1 on them. larg battery up front and larg deep cycle batt in the back. ive got a 210 amp ohio gen alt an isolator. at night i stil have the whole headlight dim thing an voltage drop. What should i do, ad stock alt back on for front batt and use the large alt for the audio end. or what is most likley the cause , and how to fix it. just to add , all this was put in by audio shop in tulsa ok
you got vids of the subs?sounds like it's crazy!
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
get rid of that isolator, it blocks most of the current flow to back battery, ied just put a fuse inline with it and be that, ive had mine wired with front battery for about 2yrs now and nothin wrong and no voltage drop at all, but i dont have half the shit u do tho, but ied try takein the isolator out and just straight wire the front and rear battery together like pos of front to rear pos and so on, and that should fix, i heard isolators blocked most of the current just to save front batterys amprage to run the rest of the car like engin and assories, and might be an ohm load also, i got a 130amp stock alt under the hood, with a duralast gold top 950amp in front and a stinger sp800 in back and i took out my 2 mtx 5500 15's dual 4ohm and i useto have it wired 1ohm(its 1ohm stable) and now i got my mtx 8000 15 single 4ohm and now its at 2ohm and no dimming at all, try that should work, im not sayin u dotn kno ur ish but little shit can be looked over really easy
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
Done the big 3 yet?
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Done the big 3 yet?
Get rid of the isolator. You essentially only are running off one battery when you have an isloator installed. Just parralel the two bats together and you will have twice at much battery researve. Additionally, the charge voltage to the rear battery will be aprox. 1 volt higher, (without the voltage drop through the isolator) so it will be charged much better.
what about using my stock alt just for the engine batt, and using the big alt just for the audio end. that way they would be sepperate
you can always do it like that. have your highs amp running at the stock alt and then ya HO alt handling ya sub amp(s).......
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 979 Guests (See full list)
