Gearstix Posted September 21, 2008 Report Posted September 21, 2008 We have three Fleetrite batteries. There normal batteries, I don't think there deep cycle or AGM, just lead acid ones. I think there 925CCA, might be more. I'll go snap some pics. Would I be able to use these to power an amp or two, it'll either be two amps 1500W each or one amp around 3000W. They will be going in the bed of my truck and will be sealed off from the cabin air... if that matters. 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
Gearstix Posted September 21, 2008 Author Report Posted September 21, 2008 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
dmanson Posted September 21, 2008 Report Posted September 21, 2008 they are better than nothing but a couple of AGM batteries would be better. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
Sampsonite Posted September 21, 2008 Report Posted September 21, 2008 x2, but there really isn't enough info in the question. what exact amps will you be running? circutry? and for daily or spl? And the wire you use and alternator are just important as the batteries --Sampson 816-591-6592 www.kcrimshop.com
Gearstix Posted September 21, 2008 Author Report Posted September 21, 2008 x2, but there really isn't enough info in the question. what exact amps will you be running? circutry? and for daily or spl?And the wire you use and alternator are just important as the batteries 0 gauge... Going with a 200+ amp alt. Thinking about ordering some KnuKonceptz wire. I haven't decided on an amp yet.. trying to do that.. http://www.caraudio.com/forum/showthread.php?t=349117 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
bangin_explorer Posted September 21, 2008 Report Posted September 21, 2008 I haven't decided on an amp yet.. trying to do that..http://www.caraudio.com/forum/showthread.php?t=349117 i agree with ssackett in that thread. very strong amps. gonna be hard to get one for $700 to canada tho. edit....... check that Canadian car audio place. they seem to have quite a bit AB floating around there oh and sorry for the off topic. i forgot it was about batts, duh. ....................................................... ROE Ref's- Pornstar, Peas247, Speedcult, 98Tahoe, 2k1 sdime, 20blackls00, acidboy, t00sh0rt KICKERASSMAN, TheDukey42, RapidFire89, bass-aholic, xhilr8n , GavRiley2007, Jalat, checkmate kstms, kingscratchie, F3RR3T, Audiobahnfreak, + more... SMD Ref's- Chode69, kingsuv, pstone11, *1LOWSUV*, kbreudi, RatBass1998, Applejack, jonathancullen89, Audioman21, Derrick824, 96saturnsl, Caps, spl explorer, littleitaly1990, tudski, sebXC, mbdblue, j_black10, tre4chevyryda, zfrerichs... CAC Ref's- forceww, alex95sl2, canyouhearmatt, flores210, Anime Freak, iamtheone, dcmcki, rcpease, jigga jatt, mytyeerinpie... THAT IS TRUE SUB PORN...got some sexy movement and a squirter Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move.
MECHMAN Posted September 23, 2008 Report Posted September 23, 2008 If the batts are in good condition, they will work OK. From the looks of them they have been leaking acid out the vents. If they don't load test well, they will do more harm than good for your charging system. 1-888-MECHMAN www.Mechman.com [email protected]
