Guest MegaloManiac Posted January 8, 2007 Report Posted January 8, 2007 What do you mean that they don't mix, I put the started in the starter spot and the deep cycle in the back to run the system. What is wrong with that? read this whole thing, http://www.stevemeadedesigns.com/forums/in...hp?topic=2636.0 , ask questions threre if necessary about it Quote
Slinky Posted January 10, 2007 Report Posted January 10, 2007 yeah man, i have the same sitiation(yellow in front red in back) and i have huge voltage problems. Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
subaru18 Posted January 11, 2007 Report Posted January 11, 2007 Well, minus all the yellow/red discrimination. What battery terminals? Quote
Guest MegaloManiac Posted January 11, 2007 Report Posted January 11, 2007 knukonceptz http://www.knukonceptz.com/productMaster.c...ery%20Terminals make sure u get 1 pos and 1 neg, and not 2 pos or 2 neg. they are different sizes. Quote
subaru18 Posted January 11, 2007 Report Posted January 11, 2007 While I am getting things from knukonceptz, if I am running two runs of 1/0 to my second battery do i need one fuse for each run? Also, do I have to fuse from my second battery to my amp? Quote
Guest MegaloManiac Posted January 11, 2007 Report Posted January 11, 2007 While I am getting things from knukonceptz, if I am running two runs of 1/0 to my second battery do i need one fuse for each run? Also, do I have to fuse from my second battery to my amp? fuse every indivisual new run of wire. fuses prevent fires Quote
hammerdown Posted January 15, 2007 Report Posted January 15, 2007 fuse every indivisual new run of wire. fuses prevent fires I'm running 8 amps and looking at running 2 awg to my amps from 6 batteries in the rear. Now I'm looking at 2/0 from the alts. To the rear batteries and from the rear batteries I'm running 4 dual anl fuse blocks 150 amp anl fuse on each side. Is this a good thing or do i need to have the 2awg wires coming from the batteries to their own fuses then to each amp. the main fuse is a 300amp fuse Quote
dmanson Posted January 15, 2007 Report Posted January 15, 2007 as i have always understood multiple runs. each run coming from the front battery needs to be fused within 18 inches of the battery. when the run(s) reach the back, then you fuse them again ...... 18 inches from battery(s), and from those battery you can run it to the amp(s), distribution block or whatever ..........wouldn't hurt to have a fused distribution block either Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
