ok so I was wondering if anyone knew what 8 rockford fosgate P1, tuned to 30hz would sound like or if it would even hit that... the P1's are 300watts but I'll push 420watts to them...
when i get to it ill draw up a pic of how it would be set up.
thank you.
I can't stop building!!!
4 DC LeveL 4XL 18 Blow Through Re-Build
The newest addition My '97 Ford Explorer Build
My First Build 8 RF P1 12's
My Myspace Add Me
My Facebook Add Me
oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you?
If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up.
thank you.
What size?
And I'm pretty sure even 8 10's would sound damn good.
What size?
there 12's
My Myspace Add Me
My Facebook Add Me
thank you.
My Myspace Add Me
My Facebook Add Me
420 watts to each P1??
thats well over its MAX power. if your gonna do that much power do P3s or step up to another sub thats rated for 400 watts RMS. i do not recommend that much power to those subs
Yeah I had thought about it more lastnight, and I decided that I would get a 600watt and have the right wired in series\parallel to one channel then the left wired in series\parallel to the other channel.
the most thing I want to find out is if its a good idea to have it at 30hz.
My Myspace Add Me
My Facebook Add Me
But then you're only getting 300w/side... so 75w per sub, and that's not going to wang...
30hz is very low. You'll gain a lot of output just by moving up to 35 or 38hz.
10.x volts fo' life!
If your set on the P1s then get a pair of p500-1bd amps and wire each side parallel to each amp. It should move some air, your better of tuned around 35 hz. My older brother has 4 P2 15s run off a ZX1000.1 and its just starting to do a :hairtrick: ! You will have more cone and more power, so it should wang perty good!
ok but im kinda on a lil bit of a budget.
and also do u think that ill be able to do the :hairtrick: ???
My Myspace Add Me
My Facebook Add Me
  • Who's Online   0 Members, 0 Anonymous, 2296 Guests (See full list)
