94 Civic Spl Enclosure Trunk Only
SPL KID
Guest Powered By Hate
concrete that bitch.
DO IT and you'll get the :shok::shok::shok::shok::shok::shok::shok: from your friends and the :rofl::rofl::rofl: from the fearful and the haters. You could do something that makes you able to drive the car.. like more batteries. but not alot.. a few. kinetik 800's
well today i banged out the uneven imperfections in the trunk sealing. It was hit at one point in time. I bought some spray can bed liner but it just seems to wipe off. I wanted to get some herculiner but it's like $80 for the size i'll need. I'm gonna great stuff all the natural holes in the trunk area. Then fix my trunk latch so it seals closed once again (moved after fixing the pushed in areas.
What do you guys suggest to use to deaden back there thats pretty inexpensive.....besides concrete. Concrete sounds promising but I think I would need alot!
NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! TEAMHIGHX-CURSIONsig-1.jpg
Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
I won't be doing any IASCA or Db Drag more then likely. I compete in NSPL. Yeah I may have to go to the Mats. Anywhere to get matting cheap??
about what size do you suggest I need a new box anyway. found water damage on the current enclosure. wood swelled up some parts.
I also found some bedliner spray gonna coat trunk couple times with it.
Any Ideas on box configs and size would be greatly appreciated!
I want to http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif from out the trunk!
just a few suggestions. Try subs up and port up. Worked well in my GF's civic. She ws able to pull 153.5 and consistant 152's out of her civic running 2 12's and 2 kx1200's tuned at 53-54hz and burping 56-57 hz
The old street box was tuned to 32hz with 2 10l7's and a single zx1500.1
She ran this setup running usaci Street beat and was consistant in the 143-144db range while playing late night tip and some low yin yang stuff.
wish I could give exact box specs but we were using entirly diffrent equipment then you
www.batteriesareus.com
Home of Audioforce and The V Batteries
USACI Credentials
2009 0-1000 Trunk World Record 154.0db
2009 1001+ Trunk World Record 153.2db
2007 1801-3000 Pro Stock World Champion
2007 1801-3000 Pro Stock World Record
2006 1001-5000 Pro Stock 2nd Place
He's something different:
4 subs mounted isobaric style with a slot port tuned to 38 hz, maybe....
You don't see that many isobaric setups due to their drawbacks but you never know...
just make sure that te woofers mounted on the outside are wired inversely so that their cones move in the same direction as the ones mounted in the box.
Posted Image
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
That fails, totally. Ignore it, if we're honest.
You're 3db down for the same power for a start due to using isobaric and 38hz is going to give you shitty numbers on the termlab.
It's not like you're short on volume so why anyone in your situation would even consider isobaric is beyond me.
EDIT: You don't see many isobarics because they're rubbish and have very few sensible applications.
10.x volts fo' life!
  • Who's Online   1 Member, 0 Anonymous, 1802 Guests (See full list)
