Increase the budget, if you want 1200 watts each then you want something that willl do the job like the Sundown SAZ-3000D
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
holy shit u dont need that much, they are cheap pioneers lol. a 3000d would blow them up unless its almost off. dude there are alot of amps, u dont even need to spend that much. i have to go but when i get back ill find you an amp. but for now, since they are svc4ohm in parallel its final imp. is 2 ohms. most kicker amps put out max power at 2 ohms. otherwise if you are looking to upgrade and maybe add 2 more subs get a 1 ohm stable amp that does 1000-1200wrms at 2 ohms. do not get a 2 channel amp, it will be a waste of money since u cannot use all of its power. go mono. ill help you when i get back home
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
go with one of those kenwood amps
you sure your subs aren't dual 4? ts-w306c?
I have 2 svc 4 ohm 12's wired to 2 ohms. I've tried 4 amps so far and my kenwoods by far the best.
It's the 1700 watt peak model kac-something or other.
Edited by alvitae
