Well basically I want a pretty basic alarm and maybe with remote start for fairly cheap, But really all it has to do is detect if like someone bumps into my car or like lifting the handle trying to open the door, just something pretty basic thanks for your help
Also would this do what Im asking? or no?
http://www.sonicelectronix.com/item_10664_...ity+System.html
yep that'll do everything you need except remote start.... there are alot of good alarm manufacturers to choose from any two or three channel alarm with a shock sensor will work... personally I don't venture away from autopage or any of directed's brands viper, clifford python..etc.
The 350 will have a shock sensor, so when people bump your car it will go off. There is no remote start on that model, and depending on how the door triggers are setup on your car it might not go off if you lift the handle... the door will more than likely have to be fully opened.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
the only way the door handle sets it off is if you have a car like mine where the light inside turns on if you lift the handle. 99% of cars dont do that though, so u have to settle for shock/all points of entry
http://www.sonicelectronix.com/item_6687_Viper+560XV.html <next step up in dei basically, more range, shock sensor, trunk release, remote start
Team DC
Easy way to tell if your alarm will go off from lifting your door handles before putting the alarm on is.
Go out to your car, have your doors locked. Pull up on the handle (with the door locked so it dont open). If your dome light comes on with the door still closed, the alarm will go off.
Alarms have dome light supervision, which montiors the dome lights going on and then triggers the alarm, if your lucky to have a car that the light goes on by lifting the handle your alarm will go off, otherwise the theifs would get into your car by the time the light supervision activates, or the door pin is fully depressed.
