Posted (edited)
I am planning to do the BIG 3 upgrade on my alternator and i dont know what size to use. The car is a 1990 toyota camry 4cyl. I will be running about 2000+ rms in amp/s power. Will it sound any different if I do the change.
Edited by jazza02
australia03junehl4.gifCURRENT SET UP
Factory HeadunitGladen dual splits
Audio helon 4ch amp
Audio Helon 9kwrms monoBlock
2 15" Custom built Pap subs rated at 3kwrms each
run 1/0 potna
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
could i replace all the ground wires before i replace the postive wires. I wont change the positive wires till about 3 months after i changed the ground wires. will this hurt the amp or alternator in anyway?
Audio helon 4ch amp
Might i ask why do i need that for?? And where do i put it
Audio helon 4ch amp
