EricM9104 Posted October 20, 2008 Report Posted October 20, 2008 well..? Came with a 100a ANL fuse. rated for, 1500W RMS @ 1ohm, 950W RMS @ 2ohm, and 600W RMS @ 4ohm. 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
wL<3bass Posted October 20, 2008 Report Posted October 20, 2008 well..?Came with a 100a ANL fuse. rated for, 1500W RMS @ 1ohm, 950W RMS @ 2ohm, and 600W RMS @ 4ohm. 14.4v x 100a = 1440w @ 100% Efficiency So I would say no. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
MickyMcD Posted October 21, 2008 Report Posted October 21, 2008 I disagree with that rule. Under the same reasoning, PowerSoft amplifiers wouldn't be able to do 9000w from a 240v 10a supply. But they do, becuase of stiffening and buffering capacitors in the unit power supply. However, neither the PowerSoft or the Audiopipe will do that wattage from go to no continously, only in short bursts (such as kick drum, bass beats etc.) If you want her to run that sort of power non-stop, she simply won't. I installed an AP15001D in me mate Doug's vehicle for a bit of nice low end, and I was very happy with it. I did not run it at 1 ohm or anything near that, but rather around the 2.5 - 3 ohm mark @ 35hz and she did a solid 945wrms from our last test. I rate it. Cheers, Mick Work;DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS VeniceMeyer Sound CQ-1's, CQ-2's, PSW-2'sRAMSA Monitor AmplifiersP.Audio MonitorsBSS OMNIDRIVE and SoundwebDBX 231 and Klark Teknik DN360 EQ'sRCF TT22ARCF ART320
littleitaly1990 Posted October 21, 2008 Report Posted October 21, 2008 14.4v x 100a = 1440w @ 100% EfficiencySo I would say no. although I agree it probably wouldn't do rated...Rockford T15k might break that rule a little...I'm just saying. A vitrolic, megalomaniacal sadistic psychopath.
Forevrbumpn Posted October 21, 2008 Report Posted October 21, 2008 Audiofanatics is here, he will let it be known....... Altho, someone did just bring this up in a thread, same question, but I think the model above the one your asking about.... I dont think these amps do rated at all I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
MickyMcD Posted October 21, 2008 Report Posted October 21, 2008 although I agree it probably wouldn't do rated...Rockford T15k might break that rule a little...I'm just saying. It is a pretty good rule of thumb, you are right. But there are many exceptions. Again, I got the amplifier to do rated power quite easily with stiff electrical. Cheers, Mick Work;DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS VeniceMeyer Sound CQ-1's, CQ-2's, PSW-2'sRAMSA Monitor AmplifiersP.Audio MonitorsBSS OMNIDRIVE and SoundwebDBX 231 and Klark Teknik DN360 EQ'sRCF TT22ARCF ART320
