DUBIE Posted November 9, 2008 Report Posted November 9, 2008 ok so a couple of mins ago i wired a extra battery at the back..(trunk)...but i ran out of 1/0 wire...so i just added (1) 1/0 to (+) to battery and (+) to amp...with no ground...would it keep the voltage on the battery maintained or would it discharge it...?..i taught it would keep it charged since the amp is wired to the other battery in the hood and i just added a extra battery wired straight to the amp... any suggestions?.. if its bad tell me A.S.A.P so i could remove it... Quote
Beckett Posted November 9, 2008 Report Posted November 9, 2008 needs a ground bud. Quote JS Fraser *Alpine Typr-R 12" *JBL GTO 1200.1 Sub Amp *Alpine PDX-4.100 *Rockford Fosgate Power 6.5's *Rockford Fosgate Fanatics 6.5's Both in front doors *0/1 Guage wiring from front Junction Boxes to 120AH Battery In Boot (battery removed because too small for alternator) *140 Amp HO Alternator *Alpine Head Unit -------------------------------------------------------------------------x------------------------------------------------------------------------------
EricM9104 Posted November 9, 2008 Report Posted November 9, 2008 wire the ground on the 2nd batt to the chassis Quote 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
Noobtastic14 Posted November 9, 2008 Report Posted November 9, 2008 nothing will happen if there is no ground. voltage is electron pressure flowing from high pressure (+) to low pressure (-) if there is no low pressure there is no transfer. -Drew Quote I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
dmanson Posted November 9, 2008 Report Posted November 9, 2008 if you are out of 1/0 and you have some 4 ga around you can use 3 short lengths of ga from the battery negative to frame until you get some 1/0 for ground. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
Boon Posted November 10, 2008 Report Posted November 10, 2008 Sorry, but heh, a battery with no ground. Oooh that's made my day Quote 10.x volts fo' life!
DUBIE Posted November 10, 2008 Author Report Posted November 10, 2008 Sorry, but heh, a battery with no ground. Oooh that's made my day haha yea i know...a noob thing to say...but without asking im never gonna learn... Quote
Amalan Posted November 10, 2008 Report Posted November 10, 2008 ok so a couple of mins ago i wired a extra battery at the back..(trunk)...but i ran out of 1/0 wire...so i just added (1) 1/0 to (+) to battery and (+) to amp...with no ground...would it keep the voltage on the battery maintained or would it discharge it...?..i taught it would keep it charged since the amp is wired to the other battery in the hood and i just added a extra battery wired straight to the amp...any suggestions?.. if its bad tell me A.S.A.P so i could remove it... wtf how the hell do you have this wired? you have the amp hooked up to the battery under the hood and the second battery hooked up to the amp? connect the positive and positive from the battery under the hood to the rear battery and ground the rear battery to the chassis then just wire the amp straight to the rear battery... Quote
DUBIE Posted November 10, 2008 Author Report Posted November 10, 2008 Isnt it the same thing if i wired the rear battery to the amp and ground the battery to chasis.?..its wired to the same (+) of the amp Quote
