David Posted November 13, 2008 Report Share Posted November 13, 2008 you need the new AA-SMD woofer comming soon FEB of 09 Quote Link to comment Share on other sites More sharing options...
mmatsfreak Posted November 13, 2008 Author Report Share Posted November 13, 2008 any of the choices you have above will pound with 2000w. Even the Solo X and soundstream, just because they are rated to handle 5000 and 8500 doesnt mean that they will not pound with 2000w. The juggs are good too but they were initially used as burp subs. You may want something with softer suspension and a beefy coil to play music with 2000w. I personally like using the T3 TSS for this purpose. But the Fi BTL is another good choice. RE MTs have been used alot and sounded nice but I think they are not as efficient as the BTL and TSS. really so I could use a soundstream xxx or a kicker solo x and it would sound good? I figured it wouldn't sound good since it can take so much more power. David- I would be interested in AA-SMD woofers but I'm looking for something I can buy and start working on sonner than Feb Chill Phil and Jay05 - I will take a look at your suggestions thanks. Anybody else have a suggestion or opinion? Quote Link to comment Share on other sites More sharing options...
97maxima Posted November 13, 2008 Report Share Posted November 13, 2008 some custom wmd2s Quote American Bass*DC Power Link to comment Share on other sites More sharing options...
mmatsfreak Posted November 13, 2008 Author Report Share Posted November 13, 2008 I never heard of some of these subs you are talking about.So far I'm considering the fi btl, mach5 spl-15, I would consider soundstream but the amps I will be using are .5 ohm stable, I'm also looking at the solo x 18 but I'm afraid that 2000 watts might run it but it won't be enough to sound good. Quote Link to comment Share on other sites More sharing options...
Blue Posted November 13, 2008 Report Share Posted November 13, 2008 I never heard of some of these subs you are talking about.So far I'm considering the fi btl, mach5 spl-15, I would consider soundstream but the amps I will be using are .5 ohm stable, I'm also looking at the solo x 18 but I'm afraid that 2000 watts might run it but it won't be enough to sound good. Why not run an amp on each coil on the solo. Or even better yet put 2 amps per coil. :hairtrick: Quote formerly known as Blue86f150 its a 4th order just because its tuned in the 40z doesnt mean it wont reach down and jiggle your balls at sub 30 hz frequencies. Regardless if they were dipped platinum and were stuffed in Beyonce's twat.....way too fucking exspensive this sux camel dicks Link to comment Share on other sites More sharing options...
mmatsfreak Posted November 13, 2008 Author Report Share Posted November 13, 2008 Why not run an amp on each coil on the solo. Or even better yet put 2 amps per coil. :hairtrick: wow I was thinking a 8000 watt system you are taking about a 20,000 + watt system.I have heard the solo x's are real power hungry and need a shitload of power to move. I just want like 4 15s maybe even 4 18s that will pound.Something efficent and doesn't need more than say 2500 watts to get nasty loud 2000 watts would be better if possible. Thanks for all the help so far though guys. Quote Link to comment Share on other sites More sharing options...
AI James Posted November 13, 2008 Report Share Posted November 13, 2008 Wut about the dc lvl 4 XL's cheaper then the lvl 5's but same magnet and there 2000watts no and no smaller motor and 1500rms Quote Link to comment Share on other sites More sharing options...
rizzy71 Posted November 13, 2008 Report Share Posted November 13, 2008 I never heard of some of these subs you are talking about.So far I'm considering the fi btl, mach5 spl-15, I would consider soundstream but the amps I will be using are .5 ohm stable, I'm also looking at the solo x 18 but I'm afraid that 2000 watts might run it but it won't be enough to sound good. Do you have a budget? If so, people on here might be able to help you out a little bit more. Quote BRENT1997 GMC Yukon1-DC xl18"Stetsom 2K5E3-Kinetik HC1800's 1967 Pontiac GTO Link to comment Share on other sites More sharing options...
jlgn_2000 Posted November 13, 2008 Report Share Posted November 13, 2008 wow I was thinking a 8000 watt system you are taking about a 20,000 + watt system.I have heard the solo x's are real power hungry and need a shitload of power to move.I just want like 4 15s maybe even 4 18s that will pound.Something efficent and doesn't need more than say 2500 watts to get nasty loud 2000 watts would be better if possible. Thanks for all the help so far though guys. i got an 18 solo x on a kx2500.1 and it sounds good Quote 94 3000gt 18" Kicker Solo X KX2500.1 2 KX350.4 8 JBL Coax Speakers 250A Mechman Alt Link to comment Share on other sites More sharing options...
mmatsfreak Posted November 13, 2008 Author Report Share Posted November 13, 2008 Do you have a budget? If so, people on here might be able to help you out a little bit more. I don't have a set budget but I don't want to spend too much on a system.I already have an amp, 2 15 inch juggernauts, and a dd 9515. I'm probably going to sell the jugernauts and the 9515 if I decide to go a different route than 4 juggernauts.So I was planning to buy another amp and 4 more 15s or 18s.I'm hoping not to spend more than 700 per woofer if I can and 800 on an amp.So thats about 3600.thats just a ballpark.I'm not including electrical in my estimated budget thats a separate budget. Quote Link to comment Share on other sites More sharing options...
