I have a 1985 chevy silverado. single cab.
i would like to enclose the bed and put 4 subwoofers in it, and most likely 3 amps
pushing around 2500-3000 watts rms.
should i add a second alternator? and second battery?
i have a few questions
To enclose the bed which would be the best sounding option? something like a tonneau cover? or actually seal the entire bed? and what would be the best way to go about that?
as far as getting the sound into the cab,
would it be best to make like a port vent into the cab? or another way?
i am looking to do alot of the work myself,
and just trying to get an guesstimate on total cost of all this
im just lookin what would be the best sounding option to it, now im guessing a blowthrough would be just like a port into the cab right?
best sound can be accomplished by using a camper shell and then doing a full blow through, turning it into an SUV basically.
But you can also use a tonneau and a half blow through below the window line.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
god yes, maybe like a 150-200amp alt and a deep cycle battery up front and 1 in the back. all 0 gauge around, Big 3 under the hood
oopd, didnt read that carefully, you dont need a second alternator but your regular alternator should be around 150-200amps
ok if im only using 1 alternator, would i run it to charge both batterys?
i would like to keep it with something like a tonneau cover, instead of like a topper..
big 3 under the hood?
so a blowthrough will be joining the cab and the bed? through like a ported weatherproof connection..
Are you the same guy from the off topic video thread that is all about the memphis gear?
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
  • Who's Online   1 Member, 0 Anonymous, 2519 Guests (See full list)
