Is This Setup Good Or Not?
i'd d the AQ3500d
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
From you other thread that got deleted...
I Changed A Couple Of Things Around And I Want To Know Which Setup Would Be Louder.
Old Setup:
SUB:(1) 18'' Fi.BTL (Fully Loaded)
AMP:(Two) Hifonics Brutus BXi 2008D (2000 Rms @ 1ohm,Overrated So Maybe 1700 Or 1800 Rms @ 1ohm Total 3600 Rms & Fi.BTL's Are Recommended @ 2000 Rms)
http://www.sonicelectronix.com/item_12120_...+BXi+2008D.html
(4) Screws For Terminals (Solid Connections No Leaks)
Enclosure:(1) [Ported] 8.6 Cuft. (After Displacemant) Tuned To 32hz.
New Setup:
AMP:(1) AudioQue 3500D (3500 Rms @ 1 Ohm!! & BTL's Are Recommended @ 2000 Rms) [is The Amp Good Or What?]
http://www.audioque.com/aq/AQ3500D.htm
http://www.audioque.com/aq/images/AQ3500D/AQ3500Dguts.jpg
(4) Screws For Terminals (Better Solid Connection No Leaks)
Enclosure:(1) [Ported] 6.7 Cuft. (After Displacemant) Tuned To 32hz. 3/4 MDF
Will That Be Loud?
Also If The New Setup Is Better Will It Still Get As Deep As It Would If I Had It In The 8.6 Cuft. Enclsoure Since Im Giving It More Power?
For A Lucky Quess Do You Think I'll Hit @ Leats 148db's If Not A Little Over?
P.S:Had To Make Enclosure Smaller Because Im Giving It More Power. If I Would Of Kept The 8.6 Cuft. Enclosure Sub Would've Blew. This Is My Budget So Please Dont Ask For Anything More Expensive
I Appreciate You Reading This Message Please Answer:)
No one can tell you how loud you will be, its all in the vehicle and install, and your second enclosure is still to large for the power you will be giving it provided you upgrade your electrical...
So what are you electrical planned upgrades b/c your not going to run either of those setups on a stock battery....your gonna need a HO alt and batteries.....or atleast a few big batteries (not optimas)
Edited by wL<3bass
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
Now I Already Know About The Alternators Batterys Big 3 Battery Isolators ETC. I Plan On Gettin One Or Two Iraggi 300amp. HO Alternators And 1 Kinetik HC 2400. Now Since You Said 6.7 Cuft. Is Still Too Big Then How About 6 Cuft. Even (After Displacemant)? When I Get My Electrical System Updated ETC. Will 6.7 Still Be Too Big Or Can I Move It Up To About 7-7.6 Cuft.?
Very Very Soon 2 Come???
(1):2002 Chevy Blazer Xtreme (2-dr. with Sunroof)
(4):15'' Orion Hcca's
(1):Stetsom V 14K2D
(6):Kicker PKD1 (Ampkit)
Ported:14 Cuft. (After all displacements) Tuned to 34hz. 3/4 MDF
(8):Screws for terminals (Better solid connection no leaks)
(1):Dynamat xtreme license plate kit
(1):Kenwood eXcelon KDC-X492
(3):300amp HO Alternators
(4):Kinetik HC 3800 Batts.
(1)Rockford Fosgate Power T8004 (For Mids & Highs)
(4)Rockford Fosgate Power T162S (Mids & Highs)
(3):Kicker PKD4 Ampkit (For Mids & Highs)
(1):Kinetik HC 1800 (under the hood or yellow top)
(1):Viper 5701 (p/n 5202V) ALARM
Big III will be done (beefing up my electrical system) etc.
Goal:154.9db-159.5db
the electrical aspect won't affect the enclosure (except when it comes to room) More voltage doesn't mean bigger box
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
So What Does That Mean Can I Keep The 8.6 Cuft Ft. Enclosure Still Using 3500 Rms Or Will I Have To Stay With The 6 Cuft. Enclosure I'll Be Happy If I Can Keep The Big Enclsoure. If Not 8.6 Cuft. Which I Want Whats My Max. Still Giving It 3500 Rms??
(1):Stetsom V 14K2D
What theyre saying is in an 8 cube box 3500rms is a little too much power, the box size helps control the subwoofer. In a big box the sub can move a lot more freely so with that much power it will eventually destruct it due to mechanical failure (voice coil slapping the back plate). If youre going to stick with 3500 rms then you need about 6 cubes like they said. if you wanna keep it at 8 cubes then go with less power to keep the sub safe.
Just Curious If It Was You What Would You Pick: 8.6 Cuft. Little Power Or 6 Cuft (After Displacement) All The Power/??
(1):Stetsom V 14K2D
or you can do the recommended size enclosure with a 2000rms amp.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Thats a big box 8 cubes for 3500 rms.just go with the 6 cubes and you should be safe with the 3500 rms amp id go with this one.
I Know It Will Get Deeper If I Do That But Will It Be As Loud As The 6 Cuft. 3500 Rms? I Love Loud Music So Which Ever One is Louder Is My Pick.
(1):Stetsom V 14K2D
  • Who's Online   0 Members, 0 Anonymous, 1668 Guests (See full list)
