It's Done ! Build For P2's And Mtx Ta7801
I understand the kerfs....but if your willing to share....How do you get the mdf to bend without splitting is there a trick to it?
at work we just go 3/4 - 7/8 of an inch through the thickness of the wood.
ie: if you have a 3/4" piece of MDF i would prolly go say 1/2" - 5/8" of an inch through the board this allows the boards to bend. Once the kerfs start to pinch on each other, the board stops bending so you make more kerfs if you have to bend it more or want to bend it more.
thats how i do it at work and i havent had one returned from QC yet ;)
the trick is to leave enough of the wood that that when it bends it doesnt break on the other side.
get you a small say 10 X 20 piece and do some kerfs 1/2" through your 3/4" MDF 1/8" apart from one another. youll see how it works.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
how many coats of clear did you put on the port??
that shiny is SHINY!!
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
sexy box ya got there man
what is the tuning? because that is a lot of port area, and very short
its LOOKING like at least 40hz
everything looks good bro! one note of advice is if your trying to be loud(SPL comps) i would build the box LOW as possible! Like 8-9" high and have the port with in 5" of the trunk lid..other than that i would say thats a kickass box!
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
teh box is sexy. How the P2's holding up so far?
2003 Dodge Ram QC 4.7, 3/5 Drop, 22's, Kenwood Excelon x792, 6x9,and 6.5, Rockford 25 to Life Power 1000, RE MX 15, Stinger 1/0 and Big 3 all soldered, Interstate Megatron +, 160A Factory Alternator, MLA Module
Build Pics
that amps powerfull as hell, the most ive known the older mtx 801ds could do was 1000@ 2ohm, damn they came a long way, the 1501d's hardly make 2000w@2ohm n urs a 800w that does damn nere 2000w, is the newr mtx amps birth sheets pritty much close together cause i need somethin that can give my 8000's more than 400rms each, and big props on the box hope i could learn how to curf cut, is it possable to do curft cuts with berch? ied like to try it but only wood i ever build with is berch, cause im alurgic to mdf cause the fermaldihide(sp) makes my throat burn like hell n i cant breathe when im around teh stuff even at work when we put on back pannels it irritates the hell out of me so i had to say the hell with mdf n now im stuck on berch but can u curft burch being its a multi ply plywood? cause prolly the layers will chip like hell but anyways killer skills on the box man hope those p2's will hold up, if that amp does what its said to do ied get a set of t1's n sell those p2's, anyways good luck with ur build man good skills
i feel stupid now.
Here are some specs ont he box though....
Total design volume came to 3.9999 Cubic Feet (ok, not exactly 4.0 LOL)
Ripple = [R] 5.83 dB
Tuned to 37.02 Hz
Cutoff Freq 28.12
vent air velocity at 5.17 %
Box height 13.50 inches
width 4.45 inches
length 22.90 inches
area is 60.08 inches
