Applejack's 15" T-line Vids Up
looks like it pounds. :clapping: now go to the lake and lets see if you can do a feathertrick :P
REST IN PARADISE BIG RICH (Sqmonte) never forgotten
Why do you guys ALWAYS dispute on NUMBERS?????
It's such a played out argument, so fucking annoying....
It's 12 fuckin 15's.... It's louder than you... Shut the fuck up...
/Rant
I'm so jealous, it makes me want to club baby seals. That shit gets down HARD!
dont buy from knowledge he will scam you.
http://www.stevemeadedesigns.com/board/topic/30995-official-knowledge-feedback/
just had to bring up that damn feather trick didnt ya lol
Enclosure design has a mislabel on it that i will get corrected and reposted correctly, uhoh_45 is doing a 3d of it as well with its correct dimensions listed. guess thats that i get for having my head in 2 places at once when writing shit. No worries, the fucker was built how it was supposed to be...
corrected pic added 11/26/2008 8:22 am cst
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
Thats a good sounding and looking box
I feel you about the kick drums, and rock
Sometimes, actually quit often now when I build a t-line, I just do the line a little shorter to raise the tuning- 40 hz would also be a really good number to mess with
Also, if someone is more in to rock, its okay to break the rules, and go with a sub with some slightly higher Qts, like up to the 0.50 area for better punch/kick
And if it was tuned at 40hz, on a 32 Fs sub, there wouldn't be any issues at all, due to the size of the vehicle, the transfer function will kick in, and drop the bass still down to the 20's
so after talking to kandiman he let me use his dimensions to make a sketchup of it seeing as i'd like to use this design and for others who would like it
it may look different then his specs but they are all right
Posted Image
and those vids look bad ass
R.I.P!
(Nov-29-2009)
92 explorer
current build
Posted Image
very nice work on the 3D draw up Uhoh
Kenwood DNX-893s
2 Dat 4.125's
2 Sundown Zv5 12's
Lots of Hushmat
2017 Comp Vehicle
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
newls1
kingsuv
kingsuv
Thanks for the specs
I guess I have a t-line question... Why does the width of the port vary so much? it seems to go from a "medium" width, to a "larger" then to a "smaller" and then back to around the same as it started? I realize it was said it was a taper, but isn't that usually just from one size, big or small, to the other? What is the benefit of it this way?
As Chris (kandiman) explained it to me.. :ph34r:and yes, I was listening :ph34r:
Theres a Loading chamber, an Expansion chamber, a Compression chamber, and an Acceleration chamber
And Damn good job on the 3D Mock Up!
816-591-6592
www.kcrimshop.com
Damn nice... after i saw the sketch, i was thinking about building one for my sub sooo would i be able to use this design with my subs and this specs?
Fs: 37,8
qms:5,96
qes:0.54
qts:0.49
Vas: 1.7 cu
xmax : 2.0"
rms 2,5kw
Greetz Skillless
VW Passat 3C/B6 Variant
Stock Vw Navigation System with Audio System Hi/Low Converter ( 3.sixty or something like that in the Future)
JBL Bpx 2200.1
JBL Px 300.4
Dynaudio Front & Rear
2x Ground Zero Gzuw 15xii
