So my truck tonite got stuck in 4x4 low. I was at on a driveway, facing downward, it was wet, and I always drive the truck in 2wd. Because of the angle, and how close I was to the other car in front of my, I switched to 4x4 so I would have better traction going up with out hitting the car in front of me
did it, and drove out, went to switch to 2wd, it would just blink and go back to 4x4 low
So now I'am stuck in 4x4 low, not really wanting to go over 40 mph
When I turn, I get the grinding jumping feeling, knowing that my front wheels are engaged, and I cant un lock it, get out of 4x4
anyone know what could be wrong?
this is lowered with lowered spindles, I know that is also a contributing problem there
I know 4x4s shouldnt be lowered, but the kit is for the truck, shouldnt be any problems
am I screwed?
So I went under the truck, but I cant see a whole lot because its lowered, and my jack is shit... Maybe I will ask my regular mechanic to go unlock it for me for $20 bucks
I see there is a lot of current at the fuse, I'am getting sparks like crazy, and the lights dim a little bit when I switch to 2wd... SO, I'am assuming its the switching solenoid
you da man Aaron, you da man
That worked, but now U-turning it rocks, shimmies still
now I can drive past 40, but just cant turn fast- feels like a lose wheel
neutral FTW
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
It sounds like what happened to my step dad on his dodge after off roading one day. I'm guessing that it is an independent front axel. Try getting on you belly with a flash light and check to see if your cv boots are ok. If they are, then i have no idea, if they are not, you probably lost the ball bearings, and the ball bearing cage. I'm only goin off of experience here, so it could be your problem or its not. Just my 2¢.
formerly known as Blue86f150
this sux camel dicks
Not a problem man that feeling should go away
Most 4Wds will disengage if you have it in 4lo , get it rolling about 5 m.p.h. in reverse, and shift into neutral with the regular shifter first. Then shift in neutral with the 4wd shifter ( if you have it )....then into 2wd. Stop... pull forward a little bit.... then back up a few feet again... Should completely disengage. I would NOT be rolling 40 m.p.h. in 4lo in any vehicle. 4hi maybe, but certainly not 4lo.... 4 lo is used for needed a high torque, low speed, need for high traction situations only...and NEVER on pavement
Edited by trainman0978
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
Funny you should say that I let a friend borrow my silverado about 2 months back to help him help his sister move and he was on the highway going 70 mph and he went to use the dimmert for the dash lights to make them brighter and he ended up pushing auto 4 wheel drive I was so supprised it didnt need a tranny or trans case
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
