I'm planning on running 3 Rockford Fosgate Punch P2's. They are 2 ohm woofers, each rated at 250 watts RMS. According to Rockford's website when wiring 3 of these woofers to an amplifier they can either be as a 3 ohm load or a 1.34 ohm load. What i need help with is finding an amp that is capable of handling a 1.34 ohm load at 750 watts RMS.
Any help is appreciated. Thanks
(Headunit) Pioneer DEH-P3100UB
(Speakers) Phoenix Gold RSd 65cs
(4 Channel) Alpine MRP-F300
(Subs) 2 15" Audioque SDC2.5
(Box) 7.27 cubic feet tuned to 31 Hz
(Mono Amplifier) Elemental Designs Nine.1
(Wiring) 1/0 Knukonceptz KLMX
(Batteries) 2 C&D Tech 75 a/h
look into the sundown 1000ds, hifonics lower line or just about any amp that'll do 1000X1 @ 1ohm.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Actually if they're 2 ohm woofers and you wire them in parallel you will get a .66 ohm load not 1.34, and if you were to wire them in series you would have 6 ohms not 3 ohms. I don't know where you came up with that or where Rockford would say something like that but it's completely wrong.
I'd check on the impedences of the woofers again because I don't think that Rockford even makes single voice coil subs that are 2 ohms. Check back and find out what you are actually getting.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
x2
my setup:
alpine iva-w205
fosgate t30001
rf t8004
re 6x9
2 re sx 15's
4 inch fosgate fanatic q components
hertz 6.5 comp
kicker 1/0 wiring
ipod direct connect
2 optimas batts
in the middle of rebuilding
He is right shades, didnt sound right at first, What threw you off is the fact that he said 2 ohm woofers, and not 2 ohm dvc's. :)
x2
I bet you feel like a pro huh?
I believe these are the subs he is speaking of?
http://www.rockfordfosgate.com/products/pr...S&p_status=
Since they are all dvc 2 or 4 ohm subs for the 8s, 10s, 12s, 15s. And the 10s,12s, 15s are all rated for 250wrms/500peak.
Coil wiring configs.
never said i was a pro. u did
Edited by a_plus
my setup:
alpine iva-w205
fosgate t30001
rf t8004
re 6x9
2 re sx 15's
hertz 6.5 comp
kicker 1/0 wiring
ipod direct connect
2 optimas batts
Yeah I thought that he ment that they were single 2 ohm subs since he didn't state that they were dvc's. Makes perfect sense now, but the guy shoulda included all the information since he was asking for help. Simple Ohm's Law resistance is r1*r2/r1+r2
Edited by Nightshade
1 XS Power D3100
Audio Control LC6i
Stock Deck
