Guest KyleCannon
When adding a second battery can you run the positive from the front to the back of the car and then make a ground to the chassis or do you have to run a negative as well?
Yeah, it's reallt personal choice. I prefer running pos nd neg runs, just coz i know that the path for electricity is consistent and can look pretty neat.
Previous: 1988 Nissan Patrol
Rockford T800.4
Rockford T1 15 (sealed)
Rockford 6.5 Components
Current: 1997 Jeep Wrangler
Build goals...
1x RF P300.2
4x Hertz HCX165's
Built Completes :)
Alpine 9886 Headunit
RF P300.2
RF P500-1bd
2x RF P2-D2 8" Subs, 1.3 cubes @39.5Hz
4x Hertz HCX130's
Current comment...
Satisfied for the moment, focusing on performance upgrades
Guest KyleCannon
Ah, alright... good to know. It's amazing the space the damn zero gauge takes up in the front... hahah.
You can either do both and don't forget to fuse it.
Guest KyleCannon
Should I fuse it by the second battery or up at the front battery? I have also done the big 3.
Both, really. A short in the middle of the wire would get current from both batteries, so if you don't want your car to catch fire fuse both ends.
10.x volts fo' life!
