ptcary Posted December 4, 2008 Report Posted December 4, 2008 US Amps Xterminator XT-1600.2 Will this amp actually do 1100 watts rms bridged? 200Wx2 @ 4ohms (Watts RMS) 400Wx2 @ 2ohms (Watts RMS) 1100Wx1 @ 4ohms mono/bridged (Watts RMS) $169.95 @ http://www.shipsound.com/product_info.php?...85b86298a0bc385 PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
raytard Posted December 4, 2008 Report Posted December 4, 2008 75 amps of fusing, so probably good for 300x2@2ohm rms and maybe 500x2@2ohm on a burst if you have reaaaalllyyy good electrical, like not dropping under 14.4 volts at full tilt. how would it do like almost 3 times the power @4ohm just by bridging it, im confused.... so no, not doing 1100rms, probably not even 1100 max unless its getting run at 16v and you wanna blow it Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
ptcary Posted December 4, 2008 Author Report Posted December 4, 2008 75 amps of fusing, so probably good for 300x2@2ohm rms and maybe 500x2@2ohm on a burst if you have reaaaalllyyy good electrical, like not dropping under 14.4 volts at full tilt. how would it do like almost 3 times the power @4ohm just by bridging it, im confused.... so no, not doing 1100rms, probably not even 1100 max unless its getting run at 16v and you wanna blow it Thanks, I did some searching, figured maybe someone here had some expereince with it, and was hoping it might do 8-900. PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
AI James Posted December 4, 2008 Report Posted December 4, 2008 in short , dont touch that xteriminator stuff if your looking for rated power. if your looking for 1100rms look at the xterminator xt4000d its rated at 1500 @1ohm but the 2 i tested one was 986rms and the other was 1252rms. So that kinda shows you the power discrepancies in them
raytard Posted December 4, 2008 Report Posted December 4, 2008 it very well may do 800-900@2ohm, im just saying, most likely the rms is a bit below that. its going to be hard to find something reliable for 900 watts @ the 200 dollar pricepoint, maybe look for a used amp in the classifieds? Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
bkolfo4 Posted December 4, 2008 Report Posted December 4, 2008 Even if it only does 800-900 RMS, it is a nice little amp for the money. I have used several of the 800.2's in low cost installs. No problems with them at all. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
AI James Posted December 4, 2008 Report Posted December 4, 2008 look for planet audio stuff for that price range
audiofanaticz Posted December 4, 2008 Report Posted December 4, 2008 look for planet audio stuff for that price range He means look for Boss audio for that price range.
