Quick Question About An Amp's Current Pull
for example i have an amp that does
2000@1ohm
1000@2ohm
will the current pull be the same on both 1 ohm and 2 ohm loads? even if the output power is different?
Edited by kentb
depends on allot of things. voltage, efficiency, etc. best way to find out is to get a clamp meter
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
for example voltage is constant. i'm just talking about amps in general. not really specific
the rule is this, voltage divided by wattage = amperage. less wattage, less amperage draw.
forgot about the law, so that means resistance doesn't matter?
if your amp does 2000w @ 1 ohm and 1000w @ 2 ohm. It can draw almost twice as much current at 1 ohm as compared to 2 ohms.
As a general statement,most amps will draw more current at lower ohm loads.
Lower resistance on the output means that more current will flow through the output. Voltage input at your battery source remains constant so more power has to come from raising current draw.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Your mean Watts Divided by Voltage,
I did a rough calculation and got this
2000w @ 14.4V Will Draw 138.88A @ 1ohm
1000w @ 14.4V Will Draw 69.4A @ 2 Ohms
Yes resistance matters. The efficiency and power output are directly related to resistance. An amp will have less current draw at a higher impedance because it will be putting out less power therefore needing less amperage.
duhhhh... j/k :P
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
  • Who's Online   1 Member, 0 Anonymous, 1159 Guests (See full list)
