Sub Enclosure Help
its gonna be real tight everything wise, it would be nice to have an extra~3cubes so you could fit an optimum box
...or just use 3 and throw one in your girls car or something...hint hint
noticed you have individual amps on each sub, sooo grab one more, move your rack a little bit to compensate, do 3 wide which would look ill
38wX24hX14d, port 26 wide, 3 high, 20 deep, gives 1.55cube per sub, 16.8sq in port per cube, 40hz tuning , very close to optimum specs from kicker, use some poly fill if you want lower curve and "smoother response" (port 20wx3hx27l gives 32hz tuning, 13sqin/cube if u wanna tune lower)
may be a consideration, i think 3 across would look better too
I'm with Raytard on that one. With daily drivers, sometimes less really is more. lol
i think your amps are to small and your gains are to high
R.I.P!
(Nov-29-2009)
92 explorer
current build
I would have tuned it a bit lower but the box looks pretty good. I wouldnt mount the amps to the box though. My 4 l78s shoock my sundown to death almost. I took my amps off and now there on the backside of my back seat. Not touching the box. Just an idea but keep up the good work man.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
As far as your amps go they are to small. Those 4 subs can take a good 1500rms easy. I would sell them and go with one big one.
I ended up getting a kicker 1000.1 yesterday. Big improvement overall, but is just seems like something isn't right. I think it's a little louder than the 2 10's I had orginally and the 400 watt mtx. But now running 4 10's and alot more power, I think it should hit harder than what it is. Any ideas?
No matter how hot she is, someone, somewhere, is sick of her shit.
99 Tahoe:
2-10" MA Audio
4-6.5" Kenwood door speakers
Total Amp
Sony HU
Thanks for your help ray. I was thinking about the 4 10's being on top though. I have to go pick up the other subs right now. PM your email address and I will get back with you later.
James, thats the minimum measurement up top. I could get 16 maybe 17, but I am being conservative. I will be back in a bit.
If you can....stagger the 4 10"s on top and port the back, square port like Steve has. Lots of cabin gain back there in a PT! :D
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
That was the plan originally, but a few people said the 10's facing back along with the port would hit harder. Maybe I'm just expecting too much from 10's? The prefab box I had was 2.0cf per sub making it 4cf total. I swear it would hit a lower note. The box we built is right at 6cf total. I'm thinking it's too small? Should I try some polyfill and see what happens?
From this
To this
Edited by CrashHole
99 Tahoe:
2-10" MA Audio
Total Amp
Sony HU
  • Who's Online   0 Members, 0 Anonymous, 1150 Guests (See full list)
