How To Recone A Sub
kingsuv
This makes it seem soo easy, great tutorial!
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move!
  • 1 month later...
  • 1 month later...
Heh great thread, i learned alot. I just hope I don't need to recone soon
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
  • 9 months later...
This may b a stupid question but im tryin to learn all i can before attempting a recone. About the coil. Does it just sit in the motor? Or does it get glued to the motor? Or...
Rebuild in progress...
Also what kind of CA glue? Regular, Medium, Thick? Should you use the same kind thru out the recone or should you use medium for one thing and thick for others or???
you only glue the spider and surround, the coil just sits inside the gap of the motor its needs to move up and down so do not glue your coil to the motor
87 gmc s15- 6 AB dx 12s-AB 150.1-AB 75.1-AB sq480
extras-crossfire/sundown 15-diamond audio d2 12-AB vfl 1000(hc502)-mtx 2300x
ca ic-2000 use with intsa set activator and you will use the same glue throughout the whole recone
Do you have to use activator?
Is there a limit to when you have to use the activator by?
Anybody know where I CSM get rubberized ca glue in more then 8 oz?
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
  • 2 months later...
"Black CA glue and some activator."... Is this used to glue down the rubber surround on the surface?... One of my Alpine Type R 10 sub's rubber pealed off, im thinking the glue wore off. What is the best application for this? Thanks.
iDA-X200/Clarion EQS746
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Alpine & Polk Speakers
Stock electrical
  • Who's Online   1 Member, 0 Anonymous, 666 Guests (See full list)
