Pitbullx Posted December 8, 2008 Report Posted December 8, 2008 well go buy yourself a cookie n00b Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
loburbon Posted December 8, 2008 Report Posted December 8, 2008 well go buy yourself a cookie n00bi'll do that, do you need some flea powder while im out 2000 gmc yukon 4 sundown Zv3 15's 4 dd m2a's kenwood kdc-x994 2 batcap 4000's 1 batcap 2000 dual alts. 154@37hz and climbing http://www.cardomain.com/ride/3231683 http://www.myspace.com/torque150
Charger Posted December 8, 2008 Report Posted December 8, 2008 Play nice kids or it'll end in tears..... Previous 150+ daily rides: Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470 2 x Kicked Solo X 18s, Lexus LS400 4 x American Bass HD18 walled SMD - System of The Month August 2008 My Youtube Videos
uhoh_45 Posted December 8, 2008 Author Report Posted December 8, 2008 R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
FreelandKustomz Posted December 8, 2008 Report Posted December 8, 2008 thats the same exact basic idea my box is with some other little things being tweaked. My subs were faced up and port was back also because i have a suv.
uhoh_45 Posted December 8, 2008 Author Report Posted December 8, 2008 hows this look? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
raytard Posted December 8, 2008 Report Posted December 8, 2008 just wanted to say: remember, fighting on the internet is like competing in the special olympics, win or lose, you're still a fucking retard that being said, stop fighting in the thread and offer some help if you guys know so much about these subs and the proper enclosures for them as far as that design goes, it looks ill, consider resin 45's (maybe with chop mat cut up so its kinda just fiberous junk and mixed into the resin so its stronger and not so likely to crack) to help with the airspace issue, 2 15's and a few thousand watts is alot of pressure to contain, as im sure you already knew. and im not sure who it was, but someone did a white pickup blowthrough a while back where the part of the box in the bed was disguised as a tool bin, may be a consideration, and bolt that thing in from the inside through the bed, if someone notices theyre def going to try and snatch it, noone cuts sheet metal out of their car unless theyre doing something insane stereo wise, or if theyre just insane...and im sure thiefs know that as well. Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
Boon Posted December 9, 2008 Report Posted December 9, 2008 Last box looks good except for the little lump in the triangle in the middle, that might create turbulence in the middle of your port = bad. 10.x volts fo' life!
uhoh_45 Posted December 9, 2008 Author Report Posted December 9, 2008 i figured that little bump would help out and direct the air more R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Boon Posted December 9, 2008 Report Posted December 9, 2008 i figured that little bump would help out and direct the air more Airflow is a funny thing. It might work as you say but it might also cause air to roll over it and try to go up the other side. Especially if you round over the edge of it. Think of the air as water... have you ever seen water flow over a rounded edge? You'll notice that some of it 'sticks' to the surface and follows the curve around, past the point where it would normally drop. I don't know if air behaves exactly the same but I know that little interruptions in the airflow can have some funky effects. 10.x volts fo' life!
