Buss Bar ?'s
What kind of metal do i use?
does it matter if it is ground or power?
Does it matter how long the bar is, will the ones on the far end get less power?
Can you go from 8 guage being the main, and run 18 guage off the bar?
Material wise, Copper is the best type to use as it passes the most amount of current through out.
And Im not sure what you mean by power and ground.
No, doesnt matter how long the bar is unless its like in excess of like 10 ft. All should get equal power.
And why would you be making a bus bar to run 8gauge into it then have 18 gauge come off it it???
You want either all 1/0+ for bigger amps that accept 1/0 and 4 gauge for smaller amps that are primarily used for speaker amplification.
To me, It doesnt seem like you know exactly how buss bars work. I would suggest you find someone to make them for you or do a bit more research before doing them.
I am going to be running a shit load of leds and i dont want to run them all direct to the battery, and i thought that 8 guage wire would be enough for that, then to 18 guage.
Then a bus bar is a bit of a misnomer - bus bars are normally for shifting like 500A...
What you want is a simple little terminal block or distribution block.
10.x volts fo' life!
is there a distribution block that takes wires that small?
just put all ur power wire together and put it in the block same for the ground
like steve did with the caddy
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
put them all into one or two spots of the distro block. tape the ends together or put a plastic sleeve on em so it all looks nice and pretty at the tip. the blocks just have a screw in them that will screw all the way in, so it'd eventually grab the wire either way
EDIT: eh...beat me to it :P
go to menards. they have tiny bussbars for grounds i beleive. i think it takes up to a 12 gauge wire. they have like 10 spots for wires or more.
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
  • Who's Online   0 Members, 0 Anonymous, 964 Guests (See full list)
