that is so sexy
im guessing youre using non backed stretchable carpet, right? or is it something really special?
do you start stapling at the corners? center? some random spot? start on a short or long side?
Yep..a standard non back carpet is what ya need..yes I start a couple staples on the corners and kind work things around a bit..sometimes you do end up pulling a few staples but only a few..as for the lenth..whatever you can fit..on the bigger boxes I will run half inchers.
Thats a nice wrap job.
what are you using to cover it with? is it like a fleece or something stretchy?
edit: reading>meh :(
I think that every box I ever covered that wasnt painted I used a carpet, and brush on PL Contact cement.
I think what I always did was way more labor intensive and time consuming :(
tho I guess i knew the box was pretty much water tight with all the contact cement rofl
Edited by Bangin Caddy
Its non backed carpet- the speaker box carpet, very strechable- he showed me first hand, I did it, it worked fine
Its especially great for stereo shops where you are doing a quick box But yeah, DrDB made it look to easy for me too when I was at the shop.. lol
usually we would get the carpet at keystons its a local upholsteries shop out here in sac i do believe that i found some brown colored stuff at pep boys once lol was in a rush
must be nice huh
most fabric/upholstery shops have that in a few colors and can get more its just "trunk liner" hella cheap nice raps though i use spray adhesive and staples to hold the rough spots
BIG PYMPIN IS BIG PYMPIN IS BIG PYMPIN
Thats is one of the nice things about the way I do it....no glue needed.
i was just about to ask you that. so all you do it pull and staple, pull and staple then. if so i might have to try this on a small box to get the hang of it.
----reference's----
meade916
  • Who's Online   0 Members, 0 Anonymous, 705 Guests (See full list)
