if u are referring to James's comment, he did say they werent his favorite...
i like the krystals... but they could separate at some point at the junction of the brass connection and wire... some companies encase that part in plastic so they cant separate.... but so far i like those
ive used stinger hpm's and with a little to much pulling force they ripped apart at junction too so it happens
what do u mean they ripped at junction??? an why are rcsa so important?
starting fresh, chrysler 300.. no subs amp nothin
I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click!
yeah bro Knuconceptz FTMFW... imo, i like alot of their stuff, so you could call me a lil biased, but they have quality equip.
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
Same concept as power wire. If you run a strong signal into shitty wire, you'll lose quality. However, you won't "gain" quality by using bigger ones unless you're currently using shitty wire and are upgrading. You'll just get the intended signal from the hu.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
I run the Krystal Kable, I like them a bit bulky but i like the thick casing could help protect it from getting pinched. But the junction on the ones i got have shrinktube around the connection. Also when I switched from my JL rcas to these i couldnt tell much of a difference so id say they are pretty good rcas
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
Given how terribly inaccurate most car audio setups are RCAs are the least of your concern. You would get identical sound from dollar-store RCAs and Monster ones, although they would have you believe otherwise.
There's only 2 things I pay more for in RCAs - the first is good quality construction, a car can be a harsh place for cables and if you're unplugging them a lot you don't want them falling apart.
The other is shielding. A car can be an electrically noisy place and you don't want that getting into your RCAs.
Otherwise, wire is wire. It's not like your signal is being limited by current-carrying capacity of the cable, unlike power wire where more actually = better.
Super-premium cables are bunk, IMO.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 673 Guests (See full list)
