Derrick824 Posted December 29, 2008 Report Posted December 29, 2008 40"? What kinda amp are you using? Fit it on the floor under the box.
bunkerking09 Posted December 29, 2008 Author Report Posted December 29, 2008 40"? What kinda amp are you using? Fit it on the floor under the box. fusion 4000d. I was going to put it under the false floor, but i don't like the fact that i won't be able to get to quickly if i need to
banginAltima Posted December 29, 2008 Report Posted December 29, 2008 fusion 4000d. I was going to put it under the false floor, but i don't like the fact that i won't be able to get to quickly if i need to Do you have tool box in the bed of the truck? If so put the amp there. If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
bunkerking09 Posted December 29, 2008 Author Report Posted December 29, 2008 Do you have tool box in the bed of the truck? If so put the amp there. that scares me even more. someone with a crowbar and bam. 800 dollar amp is gone.
BenH Posted December 29, 2008 Report Posted December 29, 2008 fusion 4000d. I was going to put it under the false floor, but i don't like the fact that i won't be able to get to quickly if i need to Then do it like this: 1992 GMC Sonoma 2008 MECA S1 Champ, 2010 MECA S2 Champ
BenH Posted December 29, 2008 Report Posted December 29, 2008 I highly doubt that if the subs are firing forward and the amp is partially blocking the sub it will have much of an affect on output. I ran my amps on the floor like this for awhile. 1992 GMC Sonoma 2008 MECA S1 Champ, 2010 MECA S2 Champ
Derrick824 Posted December 29, 2008 Report Posted December 29, 2008 I can't believe that amp is 40" long. The RF T4k isn't even that long.
bunkerking09 Posted December 29, 2008 Author Report Posted December 29, 2008 I can't believe that amp is 40" long. The RF T4k isn't even that long. hopefully its long enough to do this http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif
Boon Posted December 29, 2008 Report Posted December 29, 2008 I can't believe that amp is 40" long. The RF T4k isn't even that long. It's 40" long. They call it the 'Surfboard' for a reason. Also because it's actually 2 amplifiers on a single PCB internally strapped, which tends to add to the size, heh... 10.x volts fo' life!
