Blazer + Solo X 18's = Fun!
think he is talking about the steel backer ring so you can bolt them in ( i have never used mine)
i just use 1/4 lag bolts if sides flex you could put a piece of angle iron in the inside and bolt it to the side
I didint get the steel backer. I was just going to use lag bolts like you. So I think I will be fine. O and I think I have figured out how im going to brace it.
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
k. the steel ring is what i was worried about. the wall does look good so far though, should be loud.
Owner of BigAss Ports
I got some of these to brace it up! And also had to take a pic with them in their just to make sure they fit.
Posted Image
Posted Image
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Ok I have put the center port brace in. And will finish bracing tomorrow.
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
How many layer you think I should go? And are you talking about Inside the box with the 2x4? Im gonna do the back with some and and try and do the sides. and hopefully it will do. And I hope I get one of these. http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif
I would add 2 layers of resin with as much matting that you have. As for the bracing I would run a 2x4 from side wall to the port on each side, then one from top to bottom.
I don't think it's been covered but what kind of power you running ? As far as http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif , it might have one in it. hehehe :D
Drew
Ref's include: sundownz, army-killa, queball, wildsebring, foshay1123, greenman100, loud-n-low, acex3a, circa40, orangeless, PBateman,xtcxyooj, chaunb3400, oldschoolboomer, SPLluminator
Drew
Im going to do exactly that. For power I only have 1 mojo 4kw for right noe but I will be getting the other one shortly. So 2 4kw and going to get a few batts.
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Got some sanding done and the braces are in.
Posted Image
Posted Image
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
