Screw in the middle, tie a 6 inch string to it, tie a pencil to the other end and go around the screw
2000 Jeep Cherokee
-DC Audio
-Memphis
-Audioque
-SecondSkin
-Pioneer
-KnuKonceptz
so your saying a 12" sub needs a 12" hole? :01nocomment8so:
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
The best way to draw a circle would be to use a drawing compass. You can buy basic versions for as little as $1 in the school supply section.
http://www.nextag.com/Staedtler-Compasses-...5A69DE436C24781
Lots of room for error there. If you don't hold your pencil straight and don't get your string perfect your hole will suffer.
Edited by Derrick824
I just use a Router Buddy. It's cheap and easy to use. You drill a hole in the center of the circle you want to cut, adjust the jig to the right length, set the router on it and start cutting.
EDIT: Oh, you said draw. A basic compass would work like Derrick said.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
I use a cutout template and then measure it several times to be sure it is the right size. Then I cut it out- sometimes with a jig saw, but other times my Roto-Zip.
If I made boxes more often though, I would definitely go with the router and jig.... Find your center and it makes those circles "perfect" as you say.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
i use plumbers tape, bend one side into a circle and put it around a nail in the center and do the same on the other side large enough for a pencil, roll it around the pencil till its the right length then make a circle
then i cut it out with a 19$ black and decker jigsaw...aint fancy but it makes perfect round holes if youre careful enough
Team DC
i second the string/screw/pencil
07 mote carlo..
deh-p800prs hu-cdt gold 6.5's-cdt 6x9 2 ways-mcintosh mc431m(mids/highs)
bxi2608,2 10w7's in 4rth order(designed by pete k)ported into cabin via armrest cutout
dc power 260 amp alt-missing link module (15.4v)kicker 1/0 kit deka intimidator under hood
metered 141.0 @ 32hz windows down @ kick,termlab
i normally use my jigsaw. i get some damn good circles with it. but i have been using the same jigsaw for about 12 years now so i am very comfortable with it. the only time i use a jasper jig is when i need to get a box done in under a hour.
----reference's----
meade916
  • Who's Online   0 Members, 0 Anonymous, 615 Guests (See full list)
