The new system thats getting installed will be around 6000w RMS to bass, if all goes according to plan. I currently have one Kinetic 2400 in the trunk, but I was wondering if I should install another one in the trunk as well.
I dont really want to change my alternator as yea, but what battery is good for under the hood? Thanks.
http://www.kinetikaudio.com/calc.asp
6000 rms says you need 3 2400s LOL i would stick with in those parameters
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
With running 6k watts for just bass alone, I would definitely get a bigger alternator because unless you do alot of parking lot pimping, 2 batteries in the trunk isn't going to help much. I know everyone else here says Optima Yellow tops but I have a Carquest NGK battery under the hood and I have never had a problem with it.
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
Ok, so I looked it over.
This is what I am going to run:
1 KHC1400 under the hood
2 KHC 2400 in the trunk
Big 3.
Sound Good?
**Is it possible to run the batteries in parallel, then at the last battery, run the power to a capacitor, and run everything off of the capacitor? Also, since you are running the batteries parallel, do you still need to ground off the second battery and the capacitor to the chassis? Thanks.
Big 3.
Sound Good?
get rid of the capacitor. keep the batteries though. look into the MLA module to keep them fully charged.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
with 6k watts and 2 2400's and 1 1400. your going to have alot of problems with your alt. your going to fry your alt a little ways down the road. and with 4gauge your equipments not going to last too long.
so how much is an alternator that would be sufficient for my car?
Theres a couple alternator companys on this website. you can hit up the DCPOWER link that you see on the top of the page sometimes or mechman. So far i've heard alot of good things from mechman.
