is that hood flex im seeing?
R.I.P!
(Nov-29-2009)
92 explorer
current build
WELLL thats it on these for awhile guys, i actually cracked the aluminum cone tonight!!!! The system got louder and louder and then the cone busted....i think the second woofer finally broke in on my way home and then they really started unloading on the low low's...i blasted dope boy magic, and RIP.....the surround is still stuck to the cone, but it destroyed 3/4 of the aluminum tc cone....anywho, ill get some temporary 18's and put 4kw to 2 of them :) should bang pretty good.
DCAUDIO
BALLS DEEP
lets see some pics of the broken cone
edit- actually had cone first but didnt look right so i changed to basket
R.I.P!
(Nov-29-2009)
92 explorer
current build
not broken basket...cone...ill pull the subs out of box tomorrow and get lots of pix....as for the bangin it was doing?
heres some more vid
Posted Image
Posted Image
Posted Image
just for clarification this is with the factory 130 amp alternator, yellow top, and 2 sealed group 31's with one run of 1/0 +
on a mmats hd4000.1 running at 2 ohm!!!!! with the gain all the way down due to my retarded high input voltage of 6v lol
im guessing around 1500 watts clean power.
DCAUDIO
BALLS DEEP
TC /audiopulse is who i would try to get a recone from, i wouldnt trust a pierce audio (custom) recone, especially for a sub that isnt thiers and they have no clue about.
JD at T3 if you want to wait 6 months to get anything from him
Audiopulse will and can get the recone made for you underhung or not. (Kyle you spoke to works there)
Fi may be able to make you a one off recone if you send a motor to them,
  • Who's Online   0 Members, 0 Anonymous, 887 Guests (See full list)
