hey everyone i dont no if this is where im suposed to post this question so move me if im wrong. I have been looking for some cheap sound deadining material and ive been told that foam bed topping works. It is easy to cut to size and they are bendable. Now wat do you guys think, and should i go this route for under $50. Its just for the back end of my civic hatch, and will just be in the tire well and hatch on my car.?? wat do u guys think.
Heres a link of the kinda stuff im looking at but i will be buying it locally and probably go wit the 2 inch thick stuff.
http://www.amazon.com/exec/obidos/ASIN/B00...en-20/ref=nosim
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
There are a load of cheaper alternatives to dynamat.  i'd go with something intended to deaden sound.  plus its a hell of a lot thinner than 2". more like 1/4"
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
k ill keep my eyes open and you cna choose wat thickness u want i was jsut using that as an example. Do u have any suggestions for sound deadening that i could pick up at my local home depot, walmart.
System Specs:
MTX Bass Knob
80 amp stinger fuse
home depot there is something called gutter guard that is as good as dynmat orignal, also spray foam works wounders.
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
k thanks alot i will go down to home depot tommorow. i cnat really use spray foam in the tire well cause i still gotta be able to take my spare tire out if needed. I acctually made the board under the sub/amp on hinges so half of it lifts and the otha half stays stationary. Makes it easy to access spare tire. J.w do u have a link on this gutter guard i searched the home depot site and came up wit no results and searched google. Thanks.
System Specs:
MTX Bass Knob
80 amp stinger fuse
I've never been able to find it on Home depot's website. The stuff is call Protect-O-Wrap at my Home depot and alot of people refer to it as peel-and-seel. It's located in the roofing section next to the gutters. It has a silver back and is a black asphault based rubber. If you can't find it at home depot lowes carries it as well.
thanks alot guys i will be going after school to pick some of that stuff up. Ill post a pic of how it turns out. Thanks again  ;D
System Specs:
MTX Bass Knob
80 amp stinger fuse
I live in Canada i dont think that there is a lowes here. Ive never seen one. Thanks though.
System Specs:
MTX Bass Knob
80 amp stinger fuse
If you look in the build of my car you can see how I did it w/ a combo of dynamatt material (Cascade) and foam in between the interior panels. NO rattle @ all.
If you check the pics its pretty self explanitory but ask away if you still got Q's.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
  • Who's Online   0 Members, 0 Anonymous, 1046 Guests (See full list)
