Double baffle IS nessesary for spl and really so the box doesnt break apart. the baffle is the weakest part on any box and to tell the truth, it REALLY isnt that hard to make it a double. Very quick work once you have the first one done.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
I say. if you decide you wanted to have the port at the bottom, flip the box upside down, and then double baffle top and bottom since you have to cover the first hole some how, then take a cutout and glue it, and fill in the crevice with resin or silcone. Then you'll have your port on bottom. =). Easy modification. But if it sounds good like that then w/e. But I say you need a double baffle also, your going to regret it if your subs break your box.
instead of doin a double baffle can i just do like steve did and cut out around the speakers and put it on top,cuz i planned on fiberglassing the inside for support to
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
Yes you could but you haven't done it so do it! Your going to do alot of fiberglassing.
you swapped the board around so the port is on the bottom!!!???? how do you switch a board around if a box is built even half properly???
1st place circuit city car/spl show (maplewood,MN) 2006
146.6 dB's with 2 12" L7 and 1606d brutus
I think from what I read he's saying that he was just gonna cover up the port holes and baffle with some more wood. I'd just build a whole new box cuz that route is goin to affect airflow unless he resins and glasses the shit out of it.
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
I too suggest redoing the box. Maybe go it metered, play around with it some and just redo it. Part of getting loud is trial and error. Everything these guys have said is correct about the port and baffle.
Build, test, rebuild, retest...gotta love it
i was able to swap the port around cuz i never screwed that board in,i ran out of silicone and screws,and i dont get how your talkin bout not bein able to flip pieces if a box is built properly,i had the port at the top just so people can see the magnets until i got it finished,i kno there not straight cuts i gotta sand them even,im not the best cutter,and i plan on doing a double baffle im gonna make it like steves where the subs sit flush,and i plan on fiberglassing the inside
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
