Hey Steve,  How do you like that new Stinger 3/0 Power wire thats coming out or is already out now?
never heard of it....sounds interesting though  ;D
Follow my Tweet (Twitter)
ok im just curious about this one.  ok steve has 4000 watts rms running to 2000 rms subs.  can they take that much or is each speaker run at 2 ohm so it makes it 2000 rms.  just curious.
his subs are seeing 4000watts a piece. with all of the options on the subs and being smart with the gains, it can be done.
each amp is rated at OVER 4700 watts at 1 ohm.  I am at .7 so im probably pushing 5,000 to each sub.... :D
hey steve, which battery did you ground to the chassis, i figure the last battery on the bottom far right but i am wondering
they are ALL grounded together.  They are also all grounded to the chassis a few times as well as to the Alternator bracket up in the very front...The diagram just shows the basics of whats going on, its already sorta "busy" so i didnt wanna go to crazy with the specifics, you feel..... :D
yeh i had to show what meade was working with in the tahoe at work today.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
o right is taht what you used the bus bars for
Baylor University
Accounting
lol i wish i had a need for buss bars.  With only two amps, i just stack the 2 ring terminals and screw them down somewhere.  works fine as long as its hidden.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
huh?
Take the run of larger wire and cap it with a ring terminal.  Take your smaller wires and screw all the ring terminals together.  Use washers on both sides.  The only downfall is it's not fused, but neither is a buss bar.  Sorry it's kinda hard to explain.  Basically you're just sandwiching the ring terminals together to connect them.
Subwoofer Wall
  • Who's Online   0 Members, 0 Anonymous, 572 Guests (See full list)
