I'm only gonna be pushing 900 watts rms. Any suggestions?? They're gonna most likely be sealed. For now, the amp is a Sony XMGTR6001.
Edited by Tomatotat
Float mounted IPad Mini playing through Bluetooth
IStreamer for Iphone or Ipad
Rockford Fosgate 3Sixty.3
RE Audio XXX 6.5's in each door with a second set soon to be added to the front doors
Two Rockford T600-4's for the components
Blowthrough with two Sundown SA-8's
RF T1500-bd's for the subs
8000k H.I.D.'s in headlights and fogs
Lifted 2" in front and 2" in back (soon to be installed a Suspension Maxx 1.5" body lift)
17" Ultra Rogue 175's on Nitto Trail Grappler 285/17 70's
Undercover Bedcover
Surco Roof Rack
Five Hella Lights on front bumper
270A Mechman Alternator
Two Optima Yellow Top batteries
Dynamat double layered each door and roof, quadruple layered on back wall, single layered on floor with Second Skin Luxury Liner Pro on top.
rl-i
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
re sr, re se's, or even an re mx in a transmission line would sound amazing.
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
What's the best way to hook them up? Should I just get two single voice coil subs? It all needs to run into a 2ohm load.
Undercover Bedcover
Surco Roof Rack
dual 2 or single 4 (given you run 2 subs...)
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
DC lvl 3 10's, DD 1510's, RF T1 10's
Edited by Sp33dyG
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
http://www.pioneerelectronics.com/PUSA/Pro...n/TS-W1008D2|D4
i heard last years version sealed with a similar amount of power (like 1000wrms), they sound great for sq and will still thump if you need it.
Team DC
well, lemme ask ya'll this...I'm down between 2 x 10's or a single 15". Like I said, I'm gonna be running about 900 watts at 2ohms. Any recommendations on a 15"??
Undercover Bedcover
Surco Roof Rack
