yeah, thats alot of stuff. How big is your trunk?? and what are your plans for the 15's? you gonna tune em low?? or go for spl?
The trunk is fairly large, its just that the opening is small. The box will have to slide in from the cabin. 15's will be firing into the cab sealed from trunk, ports mounted in rear deck tuned to 28hz box should be about 6cf net. This will be for low end.
97 Maxima SE
Bunch of shit going in, check out the build
yumm...cant wait until this is finished..this makes me wanna go out and get another maxima to to something like this to it..
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
Small Update:
Cut the top panel and glued it in place. Cut the bevels for the front of the enclosure. I'll do the baffle tomorrow.
Posted Image
Posted Image
Posted Image
Thats it for today, gotta look for a job.
97 Maxima SE
coming along nicely , keep the pic's up.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
Another update:
Made the 1st baffle and mounted. I'm lovin how that Dewalt makes those miter cuts. Fits perfectly !!!
Test fit before glueing it in.
Posted Image
Posted Image
Posted Image
One end glued and clamped. I used the C-Clamps as stops to rest the baffle against while I used the Bar Clamp to hold it together. By the way, those Jorgenson Cabinet Master Bar Clamps are the Shit !!!
Posted Image
Posted Image
Posted Image
After the other end was glued and clamped, I set it at an angle to get a bead of glue in the seam.
Posted Image
Tomorrow I hope to get the sides done and maybe get the holes cut for the subs. Then I need to start work on the rear deck. With the stock Bose speakers there, I cannot even do a test fit, the magnets are in the way. I need to pull the deck apart to pull the speakers out so I can do a test fit of the box. While I have it apart, I'll make a template to make a new rear deck to house the ports, E8's and rear stage (for the kids DVD's hehehe)
97 Maxima SE
Another update:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
man this build just looks crazier and crazier, keep them pics coming, i wanna see you get all this in there
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
Got a little more work done on the box.
I got he bottom corners done. I had to do this to clear the rear strut mounts in the trunk.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Next week I hope to get the holes cut, dowels installed and sides done. Then I need to work on the rear deck.
97 Maxima SE
I got some more work done today. I broke open a couple of new toys I've been dying to use.
Posted Image
Porter Cable 895PK Fixed Base / Plunge Router Kit
Posted Image
Jasper Jigs from Parts Express
Posted Image
All marked up and ready to go
Posted Image
Just trying to see how it will look before I make the cut
Posted Image
Thats a big bish
Posted Image
Jasper Jigs FTMFW!!
Never has a perfect hole been so quick and easy to cut
Posted Image
5 minutes after starting...
Posted Image
Posted Image
Posted Image
Mmmmm magnet porn
Posted Image
Posted Image
97 Maxima SE
Can't wait to see how this turns out. 28hz should be insane on the lowws.
Drew
Ref's include: sundownz, army-killa, queball, wildsebring, foshay1123, greenman100, loud-n-low, acex3a, circa40, orangeless, PBateman,xtcxyooj, chaunb3400, oldschoolboomer, SPLluminator
