XS Power
My Batteries Came Today, Couple Questions
Well I got my D3400 and D3100 from MechMan today. The D3100 is resting at 12.74 and the D3400 is resting at 12.51. I don't have the Powermaster charger (can't afford it at the moment), so how should I go about charging these before I put them in? (probably in a week or two)
2001 Chevy Impala
Eclipse CD7200 mkii
Cactus Sounds 5kw
Sundown 100.4
(2) Fi BTL 18s (walled)
ID 6.5s (2 sets)
Iraggi 320 amp Alt
XS Power Batts
KnuKonceptz Wiring
MidwestSPL Scores:
152.0 Advanced 2
136.1 Extreme 3
any good agm charger should work I use a ctek 7000
What if I don't have an agm charger? Any place I could find one cheap?
2001 Chevy Impala
Eclipse CD7200 mkii
Cactus Sounds 5kw
Sundown 100.4
ID 6.5s (2 sets)
Iraggi 320 amp Alt
XS Power Batts
KnuKonceptz Wiring
MidwestSPL Scores:
152.0 Advanced 2
136.1 Extreme 3
hit up walmart or advance auto for a cheap charger.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
My friends dad has a decent Die Hard charger I can use. Just do a 2 amp trickle charge on them?
2001 Chevy Impala
Eclipse CD7200 mkii
Cactus Sounds 5kw
Sundown 100.4
ID 6.5s (2 sets)
Iraggi 320 amp Alt
XS Power Batts
KnuKonceptz Wiring
MidwestSPL Scores:
152.0 Advanced 2
136.1 Extreme 3
We recommend the 1005 Intelli-Charger, but if you have a normal "timer type" charger it is fine to use as long as you closely monitor the voltage. With a normal type charger use the trickle setting and monitor the voltage closely to make sure it doesnt exceed 14.9V.
XS POWER Batteries, Chargers & Accessories
888-4XS-POWER
Best charger in the world is under the hood of your car. Your alternator! :D
LOL...It isn't actually.
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
  • Who's Online   1 Member, 0 Anonymous, 1352 Guests (See full list)
