Torres' Box Tuning Calculator - Updated 8/18
Torres
hey..
can anybody tell me from which side i can measure the physical port length..?
1. Inside the port side
2. Inside the net volume side
Help will be appreciated.. thanks in advance..
The answer is in the help section in the tabs of torres, i was going to ask the same question but i though i would re-check the help tab.
Long story short it is measured from the exterior of the box if i read it correctly.
Exterior of the box..? O.o
Sorry didn't catch you.. let me explain my question..
When we made a "L" shape port piece for enclosure then from which side we measure the Physical Port Length..?
1. Inside the "L" shape or
2. Outside of the "L" shape
RDD *ROHIT DUDEJA DESIGNS*
Yeah i misread your question, stupid reading comprehension :P
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
This would be your Physical Port Length,measure the two pieces of the port and add the numbers.
and what about the thickness of baffle.. you havn't included it.. :/
correct me if i am wrong..
That is not considered part of the Physical Port Length.
:WTFBubble: means i have done a mistake in my enclosure.. i subtracted the thickness of baffle from Physical Port Length..
Physical port length field in Torres software shows the length of what is outlined in red, the baffle is not part of it:
