Torres' Box Tuning Calculator - Updated 8/18
Torres
:WTFBubble: means i have done a mistake in my enclosure.. i subtracted the thickness of baffle from Physical Port Length..
Gladly it's a small mistake, don't worry about it.
From the help/FAQ
7 - Port length uses the box wall or baffle(s) as part of the port length.
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
From the help/FAQ
If you are uneasy with that method, just use whatever you enter as port length and measure along the center line end to end, like in the yellow line:
This is the simplest straightforward way and works without any considerations of baffle thickness. etc.
  • 1 month later...
Does the Torres Calculator account for the added length of an aero port due to its flares? Or are we to add 1" to the physical length?
F O.
It does not. Since they can be made of all different sizes, it's too hard to account for the sizes
Check the following:
With the diagram above find out what's the effective length of your port and enter that to the calculator.
Hey..
M facing some problem while designing the multi baffle enclosure..
Here is my question: when we design a multi baffle enclosure then the thickness of the second baffle is included into total external depth of the enclosure..?
#Joe if possible help me with a diagram this will be appreciated..
RDD *ROHIT DUDEJA DESIGNS*
Multiple baffles aren't "add-ons" so to speak. If you have multiple baffles, they are calculated within the dimensions given
And is this possible to use a master baffle of 1" thickness and slave baffle of 5/8 thickness..?
If yes? Then we have to fill the total thickness of baffle i.e. 1" + 5/8" = 1.625" in the port thickness section..?
