upgrade my battery....will it really make a difference. once the engine is started the alt takes over so whats the point?? i dont listen to my music when the truck is off so...
NoFearX18 said:
trainman0978 said:
upgrade the batter anyways, along with your alternator upgrade. it will make a big difference.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i will have to modify my frame to fit a bigger alt so dodge pwnt me :'(
NoFearX18 said:
trainman0978 said:
but will it be ok to upgrade my batt with out an alt upgrade
NoFearX18 said:
trainman0978 said:
Upgrading your battery will help, but it can also put stress on the alternator, of course your system is already doing that. At school they taught me that everything runs off the battery and the alternator recharges the battery. The bigger the battery load the more work for the alternator. The bigger the alternator(s) the higher the power supply to charge the batteries. You can do one without the other, but going to big on the batteries without upgrading the alternator fry your alternator.
Aldo, depends on what your alternator is rated at now.
thats what i wanted to read....i got a 117 amp alt right now.
NoFearX18 said:
trainman0978 said:
what kinda car you got?, cause surely you can upgrade alts without any mods. i went from a 90amp stock alt to a 200 amp iraggi alt...same size, bolt on. they should be able to get you one in the same size case i would think, but then again, maybe they cant...
i likes me some audio stuff...
i got a 2000 dodge dakota...4.7L V8
NoFearX18 said:
trainman0978 said:
Guest 90accordman
id get a direct fit alternator replacement as well as a better batery just to be safe
call dom
Follow my Tweet (Twitter)
  • Who's Online   0 Members, 0 Anonymous, 801 Guests (See full list)
