So i just looked at the specs..
# 4 ohms: 50W x 4 channels plus 300W x 1 sub channel
# 2 ohms: 100W x 4 channels plus 600W x 1 sub channel
# 1 ohm: 150W x 4 channels plus 800W x 1 sub channel
So can you run the sub channel at 1 ohm and the front and rear and any other combination. Or do they all have to be at the same ohm level.
I am not 100% rear familiar with 5 channel amps...
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
i went ahead and ordered one. can't wait to get it! should be here in a few days. i already found a buyer for my p400 and p500 so the amp is going to cost me less than $200. this site is crazy. the longer you're on here the more money and power you dump on a system.
you guys think this amp will require any major electrical upgrades? i've got the big 3 done and a 2 farad rf cap but that's it. right now at full tilt my voltage doesn't drop below 13.4. if i have to get a battery or ho alt that'll suck. the car is an 08 scion xb btw.
Yes you be fine with the electrical. Just don't crank the music everday because it drain your electrical.
That is exactly what ive been looking for although id like more rated power off the sub channel figure it actually does about 1000 or so. It might end up in the daily. woooo
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I'd upgrade the battery under hood and how many amps is the alt in our car?
Alpine INA-W900
Rockford Fosgate Punch 200ix
Rockford Fosgate power T1500-1
Sundown SA-10 x2
Focal 6x8's front
Rockford Fosgate Power T1682 rear
Rockford Fosgate and Stinger Wiring
Powermaster D3400, S680
x2 i was wondering about this
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
  • Who's Online   1 Member, 0 Anonymous, 875 Guests (See full list)
