Any Ideas On 2000 Gmc Denali Door Panels? 00' - 01' Swap?
Well, I might have started a little prematurely on my door panels. I want a lot of sound from the front with great imaging. I went right off the bat and cut off the bottom of the panels assuming I will just glass the bottom halves. What a mistake. Not like I already started getting all crazy with the doors. I already finished the read doors. I just took the grills, and used some rings I made to mount the mid and tweet, glued that to the grill, wrapped the grill with grill cloth then added fiberglass cloth- just thin stuff. Then a final layer of grill cloth. Done, and finished each one in about 1 hr, maybe 1.5hrs for the 2.
I carpeted the rear door pods because I bought vinyl to wrap over the carpet, but now seeing how the pod is so close, well, pressing against the seat, I' am pissed. I don't feel I really wasted anything. Just fun little pods I made .
I guess my question is, if anyone knows this, do the door panels from the late 2000 GMC, yukon, suburban, tahoe fit on the early model 2000 doors?
I assume everything will match up
See, the difference is, the late model has the vertical speaker components that are more fwd of the door, not at the bottom corner of the panel
Here are the differences.......
What I have..............
Posted Image
front
Posted Image
rear
Posted Image
how close the rear speaker pods are in the rear doors- Fronts wouldn't be much different
I guess I want to know if anyone has experience swapping from that door panel, to this one
http://image.sporttruck.com/f/10747855/030...+subwoofers.jpg
http://images.google.com/imgres?imgurl=htt...l%3Den%26sa%3DN
I can keep finding pictures, but you guys get the point
I probably can peel the grill off from the fiberglassed portion, but that will give me like 1/8" to max 1/4" more play in front of the speakers
i would have just covered the grill for the door panel in a material and cut holes in those. there should be enough room in the door. i dont think those panels are interchangable. if i am correct, i think the window switches on the drivers doors are in different positions. ill try and post a few pics of the different panels. your best bet would be to call the chevy yard on sunrise right by my work.
I Rock 4 Doors 4 More Whores!
SMD SUPER SELLER
my seller feedback http://www.stevemead...-mama-feedback/
more seller feedback http://www.stevemead...-slaps-yo-mama/
thanks B
I took the door panel off, and realized just how flat, and easy it will b to just build full off custom panels
Something plain, smooth, and just simple
Ive done door panels before that were on much more difficult panels, after taking a really good look at this, I think I can pull off a full door panel rebuild, ground up.
What I really want to do is 2- 5.5" component sets (the ones in the back doors x's 2) along with 2- 6.5" mid bass, or possibly atleast 1- 8" midbass
I just started working again, so when I get some time, I will start on this, and see what I can whip up
im gonna try and follow this thread cause im curious on how its gonna look. my hoe is gonna get its body kit and a new paint job by the end of this month. should be done early next month.
SMD SUPER SELLER
I have no problems making the door panels looking pretty descent, but will they match the truck? No.. .lol
So I may have to build a new center console, and do all 4 doors, and the barn doors in the back?
If I can talk Chris from Gatley to hooking me up in vinyling the doors, then I will be set. If I cant get him to vinyl the doors, I will just tweed them I guess
The switches, and door lights I will just do some custom stuff with. Seems every job I get, I' am stuck doing a lot of electrical modifications, so shouldn't be a problem just mounting all the window, and door lock switches in the center console, or in the door, with out that horrible woodgrain trim.
I will just need to clean my garage, so I can clean out my truck, strip it down, to where I have nothing in there so I can wire everything up
differemt panels..
sorry, Ill keep looking at your door and see if Ican come up with a plan..
I say build doors.
All to easy. takes about 13-14 hours and boom, ballin ass doors.lol
:blink: good luck on that! you have at least 2 weeks of cleaning, you have a lot of goodies in there :ph34r: . you need to go to home depot buy one of those wooden sheds for 300... if they have them down there. throw that bish on a raft in the back yard so it docent flood then clean the garage lol. really though i cant wait to see what you come up with. i didnt mean to jinks you asking if you were gonna have to make your own panels :D jooo r da manz get out there.
REST IN PARADISE BIG RICH (Sqmonte) never forgotten
Why do you guys ALWAYS dispute on NUMBERS?????
It's such a played out argument, so fucking annoying....
It's 12 fuckin 15's.... It's louder than you... Shut the fuck up...
/Rant
I'm so jealous, it makes me want to club baby seals. That shit gets down HARD!
dont buy from knowledge he will scam you.
http://www.stevemeadedesigns.com/board/topic/30995-official-knowledge-feedback/
differemt panels..
I say build doors.
Yeah, with the door panels off, its pretty easy looking. The door is very flat. All I need to do is build a base panel, a connecting point to the dash, make that match, the upper triangle area where it blends in to the A pillar, a trim piece for the door handle, and speaker rings
I' am definitely stuck on this now, I' am kinda stoked now
