My New Oscope Edit! Its Here! Pics Inside!
how long did it take you to get your scope? i ordered about a week ago, and they havent taken the money out of my bank yet. i cant use it quite yet, but i'm excited :)
  • 3 weeks later...
i tried using my scope. had it calibrated and all. and i go out to hook everything up and i'm playing my 50 hz test tone, and i see the nice curvy wave, so i turned the game up and the wave got narrower and narrower, but it never squared off. i had that gain just about all the way up just to see if i could square it off but it never did. do i have a setting wrong? or...?
i just ordered mine from www.tequipment.net as well and these are the legit ones correct? if not let me know so i can cancel this order
1999 Altima 5spd
HU: Alpine CDA-9887
Frnts: CDT audio 6.5 Components
Rears: Alpine Type R 6.5 Components
Speaker Amp: DAT HR4125
Subs: 2 AQ HDC3 15's coming soon
Sub Amps:(2)US MD2D
Wiring: Stinger
Did you check what kind of output signal your head unit was putting out. If your H/U isn't clipping, then there is a chance you could have a combination of equipment like a h/u that does 5 volts clean even at max and an amp that can take 8 volts I don't think you could clip the amp outputs. (thats wrong) maybe an amp that can take 6 volt.
Are you useing a line driver?
I have a H/U that the subwoofer output won't clip at all and does 4.65 volts and have the oposite, I own alot of amps that won't take more than 3 volts of input.
Yank the RCA's out of the sub amp and connect to the center pin and ground it at the circle and find out what your output signal looks like from your H/U.
I only use the scope with the amp set as close to full-range as possible. (Shut down all proccing on the amp)
Thats where I got mine at and have had no probblems. Very satisfied customer.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
not using a line driver. but i did get a new (new to me) cd player to replace my old one for the time being from a friend. not sure on the specs of it or anything. i need to look the manual up online. i'll try to get out and check the RCAs and all. thanks :)
  • 3 weeks later...
Got mine in Monday.. I had already set the amps with a scope i borrowed from the university but I wanted my own and figured I would give this a try. Reset both my amps tonight, very user friendly. :clapping: Great unit for such a low price ($160 shipped for me). Definitely the most important tool ive needed in my toolbox for a lonnng time :good:
  • 8 months later...
I'm bringing up an older thread... :D
I got my Velleman o-scope the other day and I love this little bugger.
Thanks to the people who found this and recommended it. Also thanks to Boon's write ups as well as ISOs write up and post on page 4.
I played with mine a bit yesterday and got things sounding much better. I didn't have it calibrated then though :angry: so I will have to do stuff again. The only thing I got to was checking the signal from my HU, EQs, and Xover. Didn't do the output from the amps yet, so no biggie. All I know is with the uncalibrated testing and quick knob turning I did on the processors- any and all hiss or previous noise (however small) is now gone. With all of the gains on the amps all the way down, the sound is much better and still pretty damn loud. It is impressive. Hopefully I will get to play for a while tomorrow. ....oh noes, time to play with new tools and settings on the stereo. B)
The wifey just doesn't get it.... but I really love my new toy.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
