Hostility Posted March 6, 2009 Report Share Posted March 6, 2009 i just built a slot ported box side firing for my ext cab s10, i have 2 RE 10" (re series) 300rms subs. now the box i have no is tuned to 36hz, and my buddy that does comps said he can build me a box and tune it high in low 40's and said it would be a lot better. but i want it loud but want it to sound good, and not just a bunch of air and noise. i like the loud low bass. what are your oppinons on what i should do? or i just sell all this and buy a single 10 or 12 se series at 600rms and get a box made? i listen to everything from metal to rap to trance music. Quote 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz Link to comment Share on other sites More sharing options...
troy Posted March 8, 2009 Report Share Posted March 8, 2009 for a good sound quality dont tune any higher. lower would even be better. Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs Link to comment Share on other sites More sharing options...
Justin Posted March 8, 2009 Report Share Posted March 8, 2009 i just built a slot ported box side firing for my ext cab s10, i have 2 RE 10" (re series) 300rms subs. now the box i have no is tuned to 36hz, and my buddy that does comps said he can build me a box and tune it high in low 40's and said it would be a lot better. but i want it loud but want it to sound good, and not just a bunch of air and noise. i like the loud low bass. what are your oppinons on what i should do? or i just sell all this and buy a single 10 or 12 se series at 600rms and get a box made? i listen to everything from metal to rap to trance music. Does he mean better for comps? How does the setup you have now sound? 40hz is higher than alot of people on here run for daily but its realy what you like. Quote 99 2dr Blazer Kenwood KVT-614 SounDigital SD16k 4 Fi BTL 18s 4 hertz high energy 6.5s comps 4 stock ad244 alts 6 g31s batts 8 runs 0ga Link to comment Share on other sites More sharing options...
The Performer Posted March 8, 2009 Report Share Posted March 8, 2009 40 hz is pretty high man, alot of guys are going with the 32hz like you have already. Your sub won't give you such a good low end anymore at that high I don't believe. And with a ported box you're going to have a rolloff where at the higher end it wont be geared so well for those kicks and such with metal. If you like alot of metal a sealed box would actually give you a more forgiving range to work with. Alot of the higher notes would still sound good, and you'd still have a decent low range for rap and such. Quote CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner Link to comment Share on other sites More sharing options...
Hostility Posted March 8, 2009 Author Report Share Posted March 8, 2009 40 hz is pretty high man, alot of guys are going with the 32hz like you have already. Your sub won't give you such a good low end anymore at that high I don't believe. And with a ported box you're going to have a rolloff where at the higher end it wont be geared so well for those kicks and such with metal. If you like alot of metal a sealed box would actually give you a more forgiving range to work with. Alot of the higher notes would still sound good, and you'd still have a decent low range for rap and such. well thats what i though, but he seems to think tuning higher is better as he said it will play all the lows still, but this if for daily no comps. the box now is alright, sounds muddy with some music. and i did have a sealed but limited me to how loud i could crank these, thats why i went with ported. Quote 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz Link to comment Share on other sites More sharing options...
Pioneer~Saturn Posted March 9, 2009 Report Share Posted March 9, 2009 It'll play the lows, yea...but not loud at all if youre tuning up in the low 40's...if you like the lows and you dont compete with this Id stick to 36 and lower honestly.. Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..." Link to comment Share on other sites More sharing options...
Sampsonite Posted March 9, 2009 Report Share Posted March 9, 2009 (edited) Just built a box, 2 15" audiopipes on 1.5kwrms in an s-10 ext cab @ 32htz. It plays all kinds of music with authority! slams the lows, does decent hairtricks, has excelent crisp kick bass. Chokes ya up a lil on higher bass. Sounds Great on just about anything you could throw at it. My guess is mid to high 40's at a low(er) frequency http://www.stevemeadedesigns.com/board/ind...c=39407&hl= Edited March 9, 2009 by footlongsam Quote --Sampson 816-591-6592 www.kcrimshop.com Link to comment Share on other sites More sharing options...
Red-navi-916 Posted March 9, 2009 Report Share Posted March 9, 2009 Does he mean better for comps? How does the setup you have now sound? 40hz is higher than alot of people on here run for daily but its realy what you like. i think he said "his friend that dose competitions" in other words his friend that competes! Quote BUILDLOG http://www.stevemeadedesigns.com/board/ind...showtopic=61862 "98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!! Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass. Link to comment Share on other sites More sharing options...
Hostility Posted March 9, 2009 Author Report Share Posted March 9, 2009 i think he said "his friend that dose competitions" in other words his friend that competes! yea ive always thought tuning lower was better, but he listened to my truck and said, yea its tuned to low, its missing a lot of the higher stuff. but i also had my deck set at 120 on lpf and hpf but i droped it to 80hz, when i had the deck set at 120 it hit all the highs hard but there wasn't many deep lows. i know these are small subs but there has to be a box that can make these things just go wild. the box i just built is ok but sounds muddy with a bunch of songs. not really impressed with it. Quote 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz Link to comment Share on other sites More sharing options...
bobonit Posted March 9, 2009 Report Share Posted March 9, 2009 If its missing the higher stuff it could be that you don't have any decent midbass. What do you have besides the subs? Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log Link to comment Share on other sites More sharing options...
