slugdub Posted March 8, 2009 Report Share Posted March 8, 2009 I finally got around to replacing my old old Rockford Punch 250a and inside the new amp box it had a diagram saying YES! and NO! Well, my Rockford amp is blown out in one channel (again, under warranty had it fixed previously) because it only gave enough bass out of my subs to satisfy me when I ran two 4 ohm speakers in parallel to a bridged amp. It says most 2-channel amplifiers DO NOT! support 2-ohm mono operation. Amplifier damage could result. Obviously this is how I ruined my amp. My question is this: What amps do handle it? Or am I just better off getting a bigger amp? I'm really just curious, since it said 'most.' Quote Link to comment Share on other sites More sharing options...
Beanz Posted March 8, 2009 Report Share Posted March 8, 2009 Why not just run a mono block amp??that should fit your needs. Quote That's why they don't deliver. Yer ass better go sit along the side of the road and wait. You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do. Link to comment Share on other sites More sharing options...
The Performer Posted March 8, 2009 Report Share Posted March 8, 2009 Why not just run a mono block amp??that should fit your needs. X2 Mono block amps are best for sub applications that don't need to be ran in stereo. Just shop around for any mono blocks that will be 2ohm stable at the rms wattage you're going to need. Most likely with the higher end amp's you'll be able to find them down to 1ohm stable even. Quote CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner Link to comment Share on other sites More sharing options...
slugdub Posted March 9, 2009 Author Report Share Posted March 9, 2009 Very good idea. Thanks! I've been looking at only 2 channel amps and even passed up on a very good deal for a mono amp that I probably could use.... and I had ruled it out. Quote Link to comment Share on other sites More sharing options...
slugdub Posted March 9, 2009 Author Report Share Posted March 9, 2009 Oh crap, how do I figure out what the wattage is going to be for two 4 ohm speakers though? I guess I need to find those old physics formulas? Or is just going to be 2ohm load.. so just take half the RMS wattage? Here is the amp I keep passing on that I can get for very cheap: Alpine 500 Watt RMS Mono Car Amplifier - MRP-M500 RMS Power at 4 ohms: 300W x 1 (1% THD) RMS Power at 2 ohms: 500W x 1 CEA-2006 Power Ratings at 4 ohms: 300W x 1 Class-D (Digital) Amplifier Type Continuously Adjustable Gain Control Dual Sided Glass Epoxy PC Board Gold Plated Input, Output, Power and Speaker Terminals Gold Plated RCA Input Connectors Adjustable Low-Pass Crossover Speaker Level Inputs Top Mounted Blue LED Power Indicator Over-Current, Over-Voltage and Thermal Protection STAR Circuitry MOSFET Power Supply Design Thermal Management Control Signal to Noise: 100dBA Speaker Impedance: 4 or 2 Ohm Frequency Response: 20 -200Hz (200Hz/-3dB) Input Sensitivity: 0.2 - 4.0V Power Requirements: 14.4V DC (11V to 16V) Quote Link to comment Share on other sites More sharing options...
07sOnAtA sp.ed Posted March 9, 2009 Report Share Posted March 9, 2009 id say get the alpine... Quote CURRENTLY UNDER RE-CONSTRUCTION 2008 Hyundai Sonata Team T3 Audio Team Deadly Hertz Team SMD (Street Motivated Devastation) Link to comment Share on other sites More sharing options...
slugdub Posted March 9, 2009 Author Report Share Posted March 9, 2009 id say get the alpine... You are probably right. You'd cringe at the other brands I've even considered. But I suck at trying to figure out if I'll ruin it hooking up two 4ohm clunkers to it. That is all I'm worried about is harming the amp. I should have been able to keep my old Rockford for another 10 years if I hadn't overrun the thing. Quote Link to comment Share on other sites More sharing options...
Team_DC-Derrick Posted March 9, 2009 Report Share Posted March 9, 2009 (edited) do you know how to wire the subs and all that? if not http://www.the12volt.com/caraudio/woofer_c...s.asp?Q=&I= that will help you out greatly how much power are you looking for at 2 ohm? http://www.caraudiodeals.com/audiopipe-ap15001d-p-1452.html 950 rms at 2 ohm.... Edited March 9, 2009 by Army_guy614 Quote The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones Link to comment Share on other sites More sharing options...
slugdub Posted March 9, 2009 Author Report Share Posted March 9, 2009 (edited) do you know how to wire the subs and all that? Good info. I do know how to wire stuff up and actually benefit from the original Best Buy install they did with my rockford amp and rockford components. I actually have a temporary amp wired in now. what I am ashamed to admit is that I don't know the actual stats on the speakers because they are sealed in the box (i've never 'seen' them), so I will open them asap so I can request help without wasting any of you people's time. that alpine amp is just such a good deal I bid on one last week then canceled it because i don't know if I can use it (max I would pay for it is $100 so.. a steal!) Edited March 9, 2009 by slugdub Quote Link to comment Share on other sites More sharing options...
The Performer Posted March 12, 2009 Report Share Posted March 12, 2009 Good info. I do know how to wire stuff up and actually benefit from the original Best Buy install they did with my rockford amp and rockford components. I actually have a temporary amp wired in now.what I am ashamed to admit is that I don't know the actual stats on the speakers because they are sealed in the box (i've never 'seen' them), so I will open them asap so I can request help without wasting any of you people's time. that alpine amp is just such a good deal I bid on one last week then canceled it because i don't know if I can use it (max I would pay for it is $100 so.. a steal!) Alot of times the subs wont say what wattage ratings are on the sub itself. What kind of subs are they, if you can get the model number then you can find out the specs. As for amps I see you're looking for multi channel amps in your other thread. Why not just go with a mono block? Alot of multichannels wont be bridgeable as they are more geared for component speakers and such. Quote CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner Link to comment Share on other sites More sharing options...
