So today i decided i am going to stick with my tline in my truck for a while or until i can get some good 18s and i am going to resin and glass this box so i needed to take it out of the truck so i figured i could do a little testing i poped in a 50hz test tone and put it on repeat
the voltage
this with the gain half way up i would put it a little higher to get the the full wattage out of it
which is around 1100-1200 watts
all i can say is wow i wouldnt ever set my gain this high but it did put this out for about 3 mins or so straight and the amp did get a little warm but not hot with the gain all the way up and 0 bass boost
this is around 3500 watts! wow i would ever do this but it shows that this amp is more than capable of putting out more than rated
i may get flamed for this but i thought id share the results with everyone who doesnt like sundown or doesnt know about the brand
Roseville, CA
the voltage
gain all the way up makes it amazing? I agree the amps are bad ass, based on testimonials, but what does it show that it puts out a lot power at full gain for 3 minutes? A LOT of people run their stuff clipping the whole time they own the car.
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
without a true rms clamp meter ur not getting the correct info.
you need to factor in amperage to get the correct true number.
Amp gain is directly proportional to radio preout voltage.
The higher the preout voltage the lower the amp gain setting.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Uhhhh, it doesn't quite work like that. I'm glad you're impressed but you will never see 3500watts out of the saz-1500d.
so how does it work?
does the speakers have to be hooked up for the ohm load?
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
  • Who's Online   0 Members, 0 Anonymous, 1667 Guests (See full list)
